When I use the DWGPROPS command in AutoCAD 2000i there are four tabs available in this dialog box. Under the "Statistics" tab, we are able to view various things such as "Created:", "Modified:", "Last Saved by:", "Revision Number:", and "Total Editing time:". On my computer, the "Last Saved by:" field is blank. I assume this is because AutoCAD looks to the operating system for this information? If you are saving files on a Novell network, this information is saved in the files' "Properties" (which you can check by right clicking on any file and choosing "Properties"). However, we are using Windows NT 4.0 which does not indicate the property, "Last saved by" when you check the files' properties by right clicking in Windows Explorer. Is this why I can't read anything after "Last Saved by:" in the AutoCAD DWGPROPS command (Statistics tab)? I know this field normally looks to the LOGINNAME system variable. When I check this "read-only" sysvar in AutoCAD 2000i, it knows my 8-digit login name. But for some reason, this login name isn't being indicated in the DWGPROPS' "Last saved by:" field. Is there any easy way we can get this information to list if we're using a Windows NT 4.0 network to save our drawing files? Incidentally, the "Revision Number" field on the Statistics tab is also blank. I realize that you must use a rather complicated procedure (involving AutoLISP) to get that field to read in the correct revision info. I'm not really interested in this latter field, but I really would like to see something in the "Last saved by:" field of the DWGPROPS command. Thanks for any help you may provide.
