Apparently there is not a direct link between the DWG Trueview/Design Review 2011 and the AutoCAD 2011 license issue.
However, I’m going to investigate deeply what could originate this problem.
For that I would need some additional information:
• In which OS and version the problem occurs?
• Have AutoCAD 2001 started correctly previously?
• Inside the directory %ALLUSERSPROFILE%\Application Data\Autodesk\AutoCAD 2011\R18.1\ADLM, there should be there a file called LicenseErrorLog.txt, can you post it please?
• When the person has tried to re-register, I suppose that have been via the online activation wizard, what message received from the system?
Regards
Antonio Barroca
Autodesk Product Support
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks:
http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
