Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
DWG TrueView does not recognize .NET 4.0
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Problems trying to install DWG TrueView 2012 on Windows 7 Ultimate, 64-bit.
I have tried installing the 64-bit version of TrueView. The installation stops and an error message says to install Microsoft .NET Framework 4.0 or higher. However .NET 4.0 is already installed.
I tried the 32-bit version of TrueView but it would not install.
I restored .NET and reinstalled all updates. Still no luck.
TrueView 2011 ran fine on this platform. However I do not have the original spurce files for that version.
Has anyone had this problem and found a fix?
Alternatively, is the 2011 version of TrueView 64-bit still available to download?
Nigel
Re: DWG TrueView does not recognize .NET 4.0
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you log a case and Product Support can send you the URL for the 2011 TrueView x64?
Can you also check out these reference posts:
http://forums.autodesk.com/t5/DWG-TrueView/DWG-Tru
http://usa.autodesk.com/getdoc/id=TS16436702
David Lau
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution.
My 5 Top Issues in the Discussion Groups
1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have this same problem trying to install TrueView 2012 32 bit on windows XP pro, I had .NET framework 4.0 already and Installed a security update for it, still no luck. error is "You must first install Microsoft .NET Framework version 4.0 or greater before installing this product."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you please try this tool to check what .net Framework you have installed in your machine?
http://www.asoft.be/prod_netver.html
Helen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, thanks much, this is the result.
<32Bit>
1.1.4322.2470
->C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322
2.0.50727.3623
->C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
4.0.30319.237
->C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
< Installed .NET Frameworks >
.NET FW 1.1 SP 1
.NET FW 2.0 SP 2
.NET FW 3.0 SP 2
.NET FW 3.5 SP 1
.NET FW 4.0 Client
I am thinking I need NET FW 4.0 "Full Framework" installed, Is that correct? I'm downloading it as I type to try it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you, that was the problem.
<32Bit>
1.1.4322.2470
2.0.50727.3623
4.0.30319.237
.NET FW 1.1 SP 1
.NET FW 2.0 SP 2
.NET FW 3.0 SP 2
.NET FW 3.5 SP 1
.NET FW 4.0 Client
.NET FW 4.0 Full ********* THIS WAS MISSING********
I got the .NET FW 4.0 FULL here
http://www.microsoft.com/download/en/details.aspx?
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah, you are right. The Full version of .Net 4 is needed to be pre-installed.
It's very glad you have resolved your problem. ![]()
Helen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That worked for me too. Thank you very much for your help!
Nigel
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you ever get a resolution? I am having the same issue with Trueview 2012 and Windows XP PRO 32bit. I have updated the Framework, including completely removing and reinstalling - no joy.
