Been trying to install this today on a Windows 7 Home Premium and it just isn't having it.
I have installed and enabled .net Framework 3.5 and downloaded the correct installer 32-bit from Autodesk and installing chokes.
The log produced shows the following:
2010/11/18:16:19:28 Ralph ACER === Setup started on ACER by Ralph ===
2010/11/18:16:19:34 Ralph ACER === Setup ended ===
2010/11/18:16:19:33 Ralph ACER === Setup started on ACER by Ralph ===
2010/11/18:16:22:29 Ralph ACER Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=2
2010/11/18:16:22:38 Ralph ACER === Setup ended ===
Would apprciate some assistance - thanks
Yous system is 32 or 64 bits ?
I ask this because you said "the correct installer 32-bit from Autodesk" and in the log there is "C++ 2008 Redistributable (x64)"
Did you ever solve this? I have exactly the same issue. I downloaded the 32 bit install and during installation on my 32 bit computer it tries to install 64 bit C++ and fails.
Ian
