Installation & Licensing
DWG Installation under Microsoft App-V
1 REPLY 1
789 Views, 1 Reply
I am trying to sequence this application to run undert Microsoft AppV but in order to do that all the pre reqs, .net4.0 C++ etc all need to be installed on the sever as these cannot be included in the sequence. My trouble is I have installed all the components from the full bootstrap installer, I extracted out all the files and ran them from the support folder, but it is still saying it is in stalling DirectX when I install the two main apps (DR andTV). How do I install the DirectX bits it needs manually?
Cheers Jonathan
1 REPLY 1
TravisNave
There is no way to remove the installer check for DirectX.  Since DirectX is built into Windows, generally this installation check is ignored by the installer so long as DirectX is up-to-date per the prerequisite check.
Autodesk Forums:
Administrator Productivity
