The ping fails. Basicly it looks like cadstuff (the license server)
asks for an address, dhcp assigns it, but cadstuff doesn't do anything
with it except ask again a few hours later. Oh, and it doesn't just ask
once, noooo, it asks twice and of course gets two addresses allocated!
The problem may be fixed now but unfortunatly it appears to be a mystery
fix. We turned off the dhcp client on cadstuff with no effect but upon
reboot it doesn't appear to broadcasting anymore requests. We'll know
for sure on friday morning if it really worked.
jerry milana wrote:
> So, if you ping the rouge addresses, the ping fails? If you get an answer
> from ping try running arp -A to take a look at the MAC addresses. On the
> DHCP servers side make sure that the rouge IPs are not reserved or held
> under lease.
> Jerry Milana,
> Autodesk Professional Services
> "rich" wrote in message
> news:3FEFFEC05A54274EA02AD05D043E7145@in.WebX.maYIadrTaRb...
>>None of that seems to apply. There is only one adapter defined in "My
>>Network Places". Ipconfig lists what it is supposed to list (one adapter
>>at the static address). Nothing exists at the rouge addresses.
>>Yesterday we tried disabling the dhcp client service on the license
>>server to no avail.
>>The only strange thing that I've found is an "Incomming Connections"
>>item in "MY Network Places" but it seems to be part of another licnece
>>managment software that uses a parallel port key. I disabled all tcp/ip
>>functions related to it.
>>sigh, it's the problem that won't go away. 4 sets of eyes have examined
>>it so far.
>>jerry milana wrote:
>>>The only way I can think of that DHCP will hand out three IP addresses
> is if
>>>there were network interfaces to assign them to. At a Command prompt
> (DOS)
>>>type IPCONFIG /ALL and see how many adapters are defined on that server.
>>>Also look at the descriptions of the adapters, some may be logical
> adapters
>>>and the description should provide you a clue as to their source. What
>>>happens if you ping these phantom IP addresses?
>>>I do not know of anything in the FLEXlm license management system that
> could
>>>trigger this behavior.
>>>Jerry Milana,
>>>"Chris Ferris" wrote in message
>>>news:74B6AF923BE487ADAE72799B9E86DCA4@in.WebX.maYIadrTaRb...
>>>>>I doubt your server is the one requesting the IP. Could it be another
>>>>>machine with the same name?
>>>>>Mike
>>>>As far as I knew, you can't do that. Computer names have to be unique
>>>>withing the same network. Depending on the DHCP server you are using
>>>>(OS wise) it should record the MAC address of the requesting machine.
>>>>Check the logs to see if it is indeed the License server that is making
>>>>the request.
>>>>It's possible that the Flexlm server software installed some network
>>>>stuff that is requesting a DHCP address. I would check the settings on
>>>>the server to see if that's the case. But this is purely speculation,
>>>>since I am unfamiliar with the Flexlm software.
>>>>Cheers,
>>>>CMF
