Installation & Licensing
Customizing a Building Design Suite Premium 2014 Deployment
3 REPLIES 3
1328 Views, 3 Replies
Is there a document that describes the different customizations and options available when creating a new deployment of Building Design Suite 2014? I'm creating a new deployment and my CAD/BIM managers would like to know what customizations and options can be automatically set in the deployment.
Lee
3 REPLIES 3
TravisNave
Step thru the deployment and screencap and document everything.  After that, there will be.  Then you can share here.  Smiley Very Happy
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Darin.Green
There's the following customizations that can be set for Revit:
Revit Server Accelerator
Customizable content directories
Customizable Application Settings
For the entire suite, the best thing is ability to add additional software to your deployment. (All deployments have this capability)
Other than what's listed above, use the following link for the Administrative Guide:
http://wikihelp.autodesk.com/Installation_Help/enu/2014/Help/0018-Autodesk18/0019-Network_19
If this information was helpful, please consider using the Accept Solution
AnkushVed
Administrator Productivity
