Is there a document that describes the different customizations and options available when creating a new deployment of Building Design Suite 2014? I'm creating a new deployment and my CAD/BIM managers would like to know what customizations and options can be automatically set in the deployment.
Lee
Step thru the deployment and screencap and document everything. After that, there will be. Then you can share here.
There's the following customizations that can be set for Revit:
Revit Server Accelerator
Customizable content directories
Customizable Application Settings
For the entire suite, the best thing is ability to add additional software to your deployment. (All deployments have this capability)
Other than what's listed above, use the following link for the Administrative Guide:
http://wikihelp.autodesk.com/Installation_Help/enu/2014/Help/0018-Autodesk18/0019-Network_19
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
