• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    mal1981
    Customization File Load Failed. File Not Found: .....Support\ACA
    4900 Views, 1 Replies
    12-02-2010 09:13 AM
    Can someone please help me? I had a user who was using AutoCAD MEP 2011 on a workstation. This user has since left our company and AutoCAD was uninstalled. Recently a new hire started and we installed AutoCAD Arch 2011 for her to use. Installation completes fine but when I open the program I get the follow error/AutoCAD message: Customization File Load Failed. File Not Found: c:\documents and settings\"username"\application data\autodesk\ACA2011\enu\support\ACA. I've tried uninstalling and deleting all the local folders I could find in the profiles local and application settings folders, but nothing is working. If I click ok, AutoCAD will open but I get no toolbars or menus. Please help. Thanks!
    Error I'm Receiving
    Please use plain text.
    Product Support
    Re: Customization File Load Failed. File Not Found: .....Support\ACA
    12-02-2010 11:32 PM in reply to: mal1981
    Delete any reference to ACA from this Registry key,
    HKEY_CURRENT_USER\Software\Autodesk\AutoCAD
    this will force the secondary installer when the user starts ACA. If the user has right permissions to edit the registry again, it will install all the necessary files.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
