• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Distinguished Contributor
    acwtzwegers
    Accepted Solution
    Customer Service Request
    160 Views, 3 Replies
    03-09-2012 07:33 AM
    although I received my licenses and key recently (exactly a week ago) from Autodesk and the first 5 installed fine, I now suddenly get 3 times "The serial number you entered is not valid. Try again". I tried again, no result.
    I pressed "Customer Service Request" but found out that the list(s) of things to fill out is longer then the ones you fill out when you buy the product (well, at least, I have no clue on what the correct answers would be as I don't have the contract on me... nor can I get it because Im actually staying longer here before the weekend so I can have these 3 machines installed and updated w/o interupting workflow.)
    Are there more "instant" solutions available or can I better also just go home and enjoy the weekend? (note that my reseller is no longer available either etc).
    :smileysad:
    Oh... in fact these 3 machines are getting downgraded from The Design Suite (Ultimate) to just AutoCAD Mechanical. I used the uninstall tool to deinstall the DS, restarted, installed ACM 2012. Could the earlier license be the problem?
    Please use plain text.
    Customer Service
    celine.manca
    Re: Customer Service Request
    03-09-2012 08:04 AM in reply to: acwtzwegers
    Hi!
    I've replied to your private message with the serial numbers details.
    Reply me back in case of issue.
    Thanks!
    Celine Manca
    AutodeskHelp | Customer Care Representative
    TW | PI | YT | BLOG
    New Member
    05-13-2013 02:42 PM in reply to: acwtzwegers
    I've sent detailed information about my situation and why I would like my student license reinstated/reset I recently bought two personal computers that I returned after installing numerous Autodesk products on them  as a last resort I decided to build my own personal computer that I accidentally install the wrong kind of operating system on  an update instead of an OEM version of Windows eight I installed numerous Autodesk products on the bad operating system and had to redo the process of installation and licensing after I bought in the correct operating system I am a student these software programs are required to complete assignments from 3-D modeling textbook and my capstone Project any help is appreciated thank you
    philip.s
    05-13-2013 04:19 PM in reply to: jblandin206
    Welcome to the community Jarrod!
    I wanted to let you know that while we do not have the ability to reset a license or corresponding activation count, our License Assistance Team, whom I believe you've contacted previously, can provide the necessary activation code once an activation limit has been reached.
    Simply fill out the previously linked form, providing your serial number + request code and an activation code will be emailed to you ASAP.
    Hope that helped clarify / please let me know if I can be of additional assistance!
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
