Installation & Licensing
Member
mikeb
Message 1 of 3 (163 Views)
Custom installation path does not seem to work for Design Suite Premium
163 Views, 2 Replies
04-22-2013 04:28 PM
want to install all of my Design Suite Premium on my D Drive instead of my C Drive. My C drive is a relatively small solid state drive reserved for Windows. I browse to the d:\Program Files\Autodesk file for teh install but when I click the Install button I get a dialog box telling me that I dont have enought space on C. Install is 9.11gb and my d Drive has 545gB available. Is there some way to force the installer to install all the various application files to D:\Program Files\Autodesk?
Employee
tony.michniewicz
Message 2 of 3 (136 Views)
Re: Custom installation path does not seem to work for Design Suite Premium
04-23-2013 10:56 AM in reply to: mikeb
When you selected an installation path on a separate drive, there are a large number of files that will be installed on your C: drive.  These include most of the pre-requisite installs, such as Microsoft Visual C++ Redistributables, files installed to the user's folder, C:\Users, Autodesk Shared files that are installed to C:\Program Files\Common Files and C:\Program Files (x86)\Common Files, as well as content that is installed to C:\ProgramData.  Additionally, the install has to extract a large amount of data to the Windows temp folder, which by default is on your C: drive.  Even though this data is removed once the installation is finished, it is required during the installation and therefore requires additional space on the C: drive.
Once all of these factors are taken into account, it is possible that you do not have enough space on our C: drive to accommodate all of these files.  You can modify Windows so that the Windows temp folder and user's folder reside on a separate drive.  Additionally, you can modify the installation settings for some Autodesk programs so that the content is installed on a drive other than C:.  As example would be Revit content, which is installed to C:\ProgramData by default but it can be redirected to another drive to save space.
I hope this information helps to clarify why hard drive space is still required on the C: drive even when you've changed the installation path to another drive.
Tony Michniewicz
Autodesk Revit QA
TravisNave
Message 3 of 3 (121 Views)
04-25-2013 08:55 AM in reply to: mikeb
Please understand that some parts of the installation files are necessary to be installed on the root system drive. Shortcuts, registry settings, and profile customizations are all examples of this. However, you may be able to make some system changes that will allow you to install your Autodesk product and avoid this error. Please review my KB article for more information:
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
