Firstly, please ensure the account used have adequate write permission to all network and local folder needed by the deployment process.
If you are encountering error during the deployment installation, you can gather some clue from the log file (install.log) in C:\Documents and Settings\ACCOUNTNAME\Local Settings\Temp folder (or you can type %temp% under Windows "Start->Run"). Ensure the correct log file is retrieved sorting by date. There will be standard Microsoft error code in the log which may explain the issue. Please attach the log and error screenshot for further review.
Thank you.
How was this resolved? I am experiencing the same issue with AutoCAD 2010 and DWG TrueView 2010.
Log File shows,
======== setup started =========
======== setup ended =========
I am attempting to create a deployment for SMS and am testing the un-install, but I continue to receive the error above regarding /SecondRun.
What needs to be done here?
Pierson Glyn-Williams
Regional Municipality of Peel
I'm having the same issue.
Log File Content:
2011/1/21:15:20:55 Administrator A07012995 === Setup started on A07012995 by Administrator ===
2011/1/21:15:21:17 Administrator A07012995 === Setup ended ===
