Installation & Licensing
New Member
Message 1 of 5 (1,686 Views)
Creating a deployment failes during setup is initializing...
1686 Views, 4 Replies
05-25-2010 01:33 AM
When making a deployement but it failes during setup. When the progessbar is almost full I get Error popup with this message
C:\DOCUME~1\\Local Settings\Temp\_AIA06.tmp\SETUP.EXE /s "G\Autocad 2011 Civil 3D\11 CD\" /SecondRun /Language en-US.
How to resolve this issue or bypass this message?
Product Support
aaronhai
Message 2 of 5 (1,682 Views)
Re: Creating a deployment failes during setup is initializing...
05-26-2010 01:27 AM in reply to: arian.muijs
Firstly, please ensure the account used have adequate write permission to all network and local folder needed by the deployment process.
If you are encountering error during the deployment installation, you can gather some clue from the log file (install.log) in C:\Documents and Settings\ACCOUNTNAME\Local Settings\Temp folder (or you can type %temp% under Windows "Start->Run"). Ensure the correct log file is retrieved sorting by date. There will be standard Microsoft error code in the log which may explain the issue. Please attach the log and error screenshot for further review.
Thank you.
Edited by: aaronhai on May 26, 2010 8:27 AM
Aaron Hai
New Member
pGwtech
Message 3 of 5 (1,656 Views)
06-17-2010 07:46 AM in reply to: aaronhai
How was this resolved?  I am experiencing the same issue with AutoCAD 2010 and DWG TrueView 2010.
Log File shows,
======== setup started =========
======== setup ended =========
I am attempting to create a deployment for SMS and am testing the un-install, but I continue to receive the error above regarding /SecondRun.
What needs to be done here?
Pierson Glyn-Williams
Regional Municipality of Peel
www.peelregion.ca
Message 4 of 5 (1,410 Views)
10-04-2010 09:38 AM in reply to: arian.muijs
I'm having the same issue.
Member
KaanTekkol3360
Message 5 of 5 (1,185 Views)
01-21-2011 05:38 AM in reply to: arian.muijs
Log File Content:
2011/1/21:15:20:55 Administrator A07012995 === Setup started on A07012995 by Administrator ===
2011/1/21:15:21:17 Administrator A07012995 === Setup ended ===
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
