• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    haisin.rusli
    Could not launch AutoCAD Architecture 2013 ( on FDSU 2013 )
    360 Views, 7 Replies
    02-05-2013 11:06 PM
    I have Installed FDSU 2013 Network version on my notebook, all software works well except AutoCAD Arhitecture 2013.
    There was a message " A valid license could not be obtained by the network license manager ". I did not know why this was happened because I could launch AutoCAD, AutoCAD Mechanical, Inventor without problems.
    I have gone to Control Panel--> Program and features--> repair AutoCAD Architecture --> but did not work,
    then reinstall  AutoCAD Architecture --> but did not work,
    Did it because of License problem? How to Fix it ?
    Best Regards,
    Haisin Rusli
    Inventor Professional 2013 SP1.1
    Windows 7 Pro 64-bit, SP1
    HP EliteBook 8460w; 8 GB RAM; i7 - 2.0 GHz; AMD Firepro M3900 -1 GB
    Please use plain text.
    DarrenP
    Re: Could not launch AutoCAD Architecture 2013 ( on FDSU 2013 )
    02-06-2013 06:20 AM in reply to: haisin.rusli
    this is a license issue
    check the status of flex lm on the status inquiry tab
    and see if there are license available
    haisin.rusli
    02-06-2013 10:42 PM in reply to: haisin.rusli
    Hi Darren,
    I have checked the status of flex lm on the status inquiry tab, but it shown no specific AutoCAD Architecture License ( maybe for version 2012 and 2013, the License was different ).
    I checked on www.licenseparser.com it shown as attached file.
    We have 6 License of FDSU and  6  License of PDSU, I thought that only PDSU that active.
    How to fix this issue ? Should I re-activeate the FDSU License again?
    Best Regards,
    Haisin Rusli
    DarrenP
    02-07-2013 06:20 AM in reply to: haisin.rusli
    does navisworks manage 2013 launch? or is it only autocad architecture from the factory suite
    DarrenP
    02-07-2013 06:21 AM in reply to: DarrenP
    do the factory design utilities work inside the inventor product?
    haisin.rusli
    02-07-2013 05:39 PM in reply to: haisin.rusli
    HI Darren,
    Yes you're right, Navisworks Manage 2013 and Factory Design Utilities inside Inventor could not launch either.
    So it must be License's issue, what should I do ?
    Best Regards,
    Haisin Rusli
    DarrenP
    02-07-2013 05:41 PM in reply to: haisin.rusli
    there is something wrong with the license file
    try redoing it
    haisin.rusli
    02-07-2013 06:18 PM in reply to: haisin.rusli
    Hi Darren,
    It's solved now, thank you for the support !
    Because there was a conflict between FDSU 2013 and PDSU 2013 Licenses ( and some other Autodesk products ), so I have to re-activate FDSU and PDSU on the same day.
    Best Regards,
    Haisin Rusli
