Installation & Licensing
Corrupt installation?
8 REPLIES 8
Message 1 of 9
itsupport
1516 Views, 8 Replies
Having difficulties with instaling AutoCAD Architecture 2011 on Windows XP SP3 x32bit
I use the installer from the AutoDesk download page.
For some reason, upon completetion of deployent package install, I am missing the express cui.
I always do the following before initiating the installation:
XP fresh install, plain OEM CD.
get all possible updates from MS Update site
download netframe 3.5 sp1 and do all MS Updates agaub
make sure I am the local administrator
go to MSconfig and disable all non microsoft services and start-up items
reboot after each step
I was told by our BIM manager that the AutoCAD installer is super picky but i just cannot see what I have missed.
WOuld anyone shed some light on this please, its been driving me boinkers for weeks.
thanks,
PS would anyone have a link to comprehensive instructions on how to remove/uninstall Autocad or Revit fully? Apparently, I was told regular uninstall is not the way to go.
8 REPLIES 8
Message 2 of 9
camilo.lemos
in reply to: itsupport
Hi there.
Please follow the instructions on this thread to perform a full uninstall of Autodesk products.
I suggest you try a clean install of the software and let us know if that works for you.
Thanks!
Camilo Lemos
Message 3 of 9
itsupport
in reply to: camilo.lemos
Thank you,
The unistall/install instructions are great.
However, following the suggestion to select "diagnostic start-up" in msconfig, this disables USB capabilities which prevents  from installing AutoCAD products from a USB drive. I do not have a DVD of any AutoCAD product since we download all our products off AutoDesk downloads as zip files. I tried burning a DVD with AutoCAD files. It does lanch the autorun setup and even lets me select the components but asks for a DVD when it comes to an "installation" part.
Instead of the suggested "diagnostic-stat up", I chose "normal start-up" but disabled all "start-up" items and disabled all non-Microsoft services. Following that, I was able to install AutoCAD well on Windows XP 32bit!
Now I am struggling with the same secenario but on a Windows 7 Ultimate 64bit. I followed the suggestions to remove all the necessery folders, registry entries from the previous unsuccessful install. The one thing to mention is that this computer has 3ds Max 2009 and 2012 loaded as well so I had to leave corresponding folders/registies in tact.
Everything is installed but the "AutodeskSeek' CUI
Maybe I need to reinstall Windows and install AutoCAD first?
Message 4 of 9
camilo.lemos
Hi there!
Can you please try this and let us know if it works:
  1. Try installing with UAC and Anti-Virus off.
  2. Make sure Flexnet Service is turned on if Standalone.
    1. http://upandready.typepad.com/up_and_ready/2011/08/licensing-using-standalone-licenses-with-selectiv...
Camilo Lemos
Message 5 of 9
itsupport
Thanks for the effort!
Unfortunately, yet again the Autodeskseek component did not load after the installation and checking with "cuiload"
What I did:
Reloaded Windows 7 Ultimate 64bit SP1
loaded all drivers and Windows Updates
Made the domain administrator (which I use to loging) the local administrator
Turned off UAC
Msconfig -> disabled all non-microsoft services.
Msconfig -> disabled all start-up items (almost non since its a fresh install)
restarted
launched the downloaded Autocad 2011 Architecture 64bit installed by right clicking and specifying to install as administrator
The funny thing, doing the exactly same thing on a Windows XP 32bit yesterday, Autodeskseek loaded just fine.
Again, BIM manager said if the Autodekseek component isnt loading by itself, something is wrong.
Is there a installation log file I could check (where?) to see what have gone wrong?
Grrr! 🙂
Thanks!
Message 6 of 9
itsupport
Bu the way, This is a network licensed product
Message 7 of 9
itsupport
Is it possible that the 64bit package of AutoCAD 2011 Architecture somehow does not enable Autodeskseek cui by default during installation? If so, how/where would I go about enabling it (very much like Express is not enabled by default during the installation)?
I cannot think of anything else I could of missed, unless Windows 7 Firewall somehow interfers?
Message 8 of 9
niranjan_kamath
AutodeskSeek.cui file is loaded while using the default installation type. The Default CUI that gets loaded with AutoCAD Architecture is ACA.cui. to Load the Autodesk Seek you may use the command MENULOAD. Use MENULOAD command and browse to the support folder to locate and load the Autodeskseek.cui and see if this helps.
 Location : - C:\Users\\AppData\Roaming\Autodesk\MEP 2011\enu\Support
You must get a message that the cui is successfully loaded. If not le me know the error that you get on the command
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
line.
Niranjan Kamath
Autodesk, Inc.
Message 9 of 9
itsupport
in reply to: niranjan_kamath
After months of testing, reformatting, reinstalling Windows, reinstalling AutoCAD, trying out a great number of cominations and settings, I finally found a solution.
During Windows 7 (any flavor) installation, if you choose anything other than "English (US)" as a language,
neither of
Autodesekseek.cui (AutoCAD 2011)
Contentsearch.cui (AutoCAD 2009)
is going to be loaded (AutoCAD 2011) / installed (AutoCAD 2009) upon installing AutoCAD 2009/2011
bug? intended? either way, there it is.
Administrator Productivity
