I'm having issues with our license not correctly cascading. What is the correct sequence of the products inside the LIC file so it will cascade properly? I have this issue that when a user used an autocad MEP and then use Manage (using 1 computer), it should drop their respective licenses and instead will get a license from Building Design Suite. But it is not doing it.
The following are our products:
23 seats = Autodesk Fabrication CADmep 2013 (86049CADMEP_2013_0F)
2 seats = Autocad (64300ACD_F)
7 seats = Autodesk Building Design Suite (85788BDSADV_F)
10 seats = Autocad MEP (65100BLDSYS_F)
4 seats = Autodesk Navisworks Manage (67600NAVMAN_F)
1 seat = Autodesk Navisworks Simulate (85838NAVSM_F)
1 seat = Autocad Revit MEP Suite (65200REVSYP_F)
is one person using multiple versions?
here is the cascading order for 2013: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708338&linkID=9240897&CMP=OTC-RSS...
DarrenP
were all the licenses generated on the same day?
this can cause issues with cascading if it wasn't
DarrenP
Yes, I checked it using the license parser and all have been issued the same day.
I believe they only both cascade to Ultimate. You might check Darren's link to verify.
