Installation & Licensing
Convert from Standalone to Network License
27 REPLIES 27
Message 1 of 28
Max_Headroom
4694 Views, 27 Replies
I have a standalone version of AutoCAD 2006 and want to license instead via our License Server.
I have exported the license to another workstation via the Portable License utility. Uninstalled AutoCAD 2006 from the original workstation. Reinstalled AutoCAD 2006 on the original workstation using a Network Deployment install set. Set the ADSKFLEX_LICENSE_FILE environment variable to point to a valid license server.
When loading AutoCAD 2006 on the original workstation it reports an error that the license has been exported and must be imported before the software can be used. (It does give me 24 hours grace period.)
How do I force AutoCAD 2006 to use the license server and disable the standalone checking?
Thanks.
27 REPLIES 27
Message 21 of 28
cpartin
in reply to: Max_Headroom
No problem. That wasn't really a solution, but I spent a good amount of time with several people who I feel are very qualified and that's the conclusion we came up with. Plus, the hack will be going away with the 2009 release so what's the point?
Message 22 of 28
TravisNave
I just installed AutoCAD 2009 and the registry fix still works.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 23 of 28
cpartin
Really? Well, I guess Autodesk is try to misinform its users then. Oh, well.
Message 24 of 28
Really? I got a bunch of problems when I did that. I was told by Autodesk
that it would be like this but maybe they made some changes in last second
anyway.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"TravisNave" skrev i meddelandet news:5884853@discussion.autodesk.com...
Message 25 of 28
TravisNave
JTB,
Yep, just did it now both ways to verify again.
Autodesk Forums:
Message 26 of 28
cpartin
When you originally installed you AutoCAD, which license did you install - the Standalone or Network?
Message 27 of 28
I got these details:
Using the registry hack, the cascading licensing service doesn’t install, so
cascading will not work, if you install network version then PLU doesn’t
install and user will not be able to transfer his license.
Jimmy Bergmark
Owner/Developer
AutoCAD 2009
"TravisNave" skrev i meddelandet news:5884951@discussion.autodesk.com...
> JTB,
Message 28 of 28
TravisNave
Interesting information.
Autodesk Forums:
Administrator Productivity
