Installation & Licensing
ContentInstalled section of Revit.ini file
1 REPLY 1
crthomas
2373 Views, 1 Reply
I have just created a Revit Architecture 2011 deployment. I chose to "Skip Content Installation" because we have previously installed on a local machine, downloaded the content, and copied it to a network share.
There are several lines at the end of the Revit.ini file under the [ContentInstalled] section (see below). Do these refer to locations where additional content will be installed (i.e. with every client install)? Or are these paths to content that must be available for the client install to copy from?
[ContentInstalled]
IES.cab=\\omfs\apps\Autodesk\Deployments\Revit Architecture\2011\x86\Content\IES
ENUSetupDocs.cab=\\omfs\apps\Autodesk\Deployments\Revit Architecture\2011\x86\Content\
SamplesRAC.cab=\\omfs\apps\Autodesk\Deployments\Revit Architecture\2011\x86\Content\
ENUHelp.cab=\\omfs\apps\Autodesk\Deployments\Revit Architecture\2011\x86\Content\
1 REPLY 1
hashim.mundol
in reply to: crthomas
http://revitclinic.typepad.com/my_weblog/2010/05/6-common-questions-about-installing-content.html
5th Question is your answer.
"The Revit.ini file is located in C:\Program files\Autodesk\Revit Architecture 2011\Program.
It contains the path information for where Revit will look for content files"
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Administrator Productivity
