Hi, I red a couple of posts about this problem but it's all related to older versions of Inventor. I'm a computer tech in a school that uses Inventor 2012. After cloning the computers, if I log in using a profile that was there before, I can access the content service but when a student logs in, nothing happen when trying to access it. I looked for the .exe.config files in the Inventor bin directory but could not find anything related to the computer name. The structure is different in this version. Is somebody experienced this problem with Inventor 2012. Thanks, Sylvain
Does this post help?
is this autocad or inventor ?
inventor doesn't have content service
DarrenP
Check out this post:
http://forums.autodesk.com/t5/Autodesk-Inventor/Imaging-Inventor-and-Current-Undo-Folder/td-p/2762334
Hi, Thanks for your help but none of these posts help. There must be something that doesn't get copied when a new user profile is created. Before imaging, I had 2 user profiles on the computer that were there before Inventor installation. With both accounts, I can use the content center option. I then deleted my profile and logged in back so I get a new fresh one created from the default user profile that was copied from a working one. Now I have the problem with my account.
I never had this problem with earlier versions of Autodesk.
I really need to find a solution for this problem, and reinstallation is not an option since it's always new students that are using the computers so it needs to work with the default profile.
Is your class using Roaming Profiles?
http://upandready.typepad.com/up_and_ready/2011/10/autocad-family-1324-error.html
NOTE: Inventor also does not support roaming profiles.
