Please help.
I'm using Windows 7 64bits and I have installed AutoCAD Architecture and Revit 2012. Recently, I had an error and had to uninstall both products. Now I am trying to reinstall, but I literally stuck.
I have tried to follow the instruction to completely remove products for a Clean reinstall by removing the product itself, folders, and registry keys. Then, I ran the installation and in the "Configure Installation" page, it says AutoCAD Architecture 2012 is installed. It has check marks next to it and it would not proceed with installation.
I believe I have completely removed everything to make sure it can reinstall cleanly. However, as it is keep on showing it is already installed, I am getting frustrated with the situation. I'm now thinking of reformatting Window itself, but I'm not sure whether that will do any good either.
Please Help.
Your instruction seems to be working. The part where it says it is already installed is now gone and I can start the Installation Process. Thank you for that.
I'm trying to reinstall the AutoCAD Architecture 2012 but it has failed.
The log file said:
2011/10/19:01:24:16 Grace GRACE-HP === Setup started on GRACE-HP by Grace === 2011/10/19:01:24:16 Grace GRACE-HP Launch 2011/10/19:01:25:00 Grace GRACE-HP === Setup ended ===
2011/10/19:01:24:16 Grace GRACE-HP === Setup started on GRACE-HP by Grace === 2011/10/19:01:24:16 Grace GRACE-HP Launch 2011/10/19:01:25:00 Grace GRACE-HP PageOpen LaunchDialog 2011/10/19:01:25:20 Grace GRACE-HP PageOpen LicenseDialog 2011/10/19:01:25:33 Grace GRACE-HP PageOpen ProductInfoDialog 2011/10/19:01:29:54 Grace GRACE-HP PageOpen ProductSelectionDialog2 2011/10/19:01:30:12 Grace GRACE-HP PageOpen FullProgressDialog 2011/10/19:01:30:12 Grace GRACE-HP Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\DirectX\DXSETUP.exe /silent 2011/10/19:01:30:42 Grace GRACE-HP Install DirectX Runtime Succeeded 2011/10/19:01:30:42 Grace GRACE-HP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/19:01:30:52 Grace GRACE-HP Install FaroSDK Succeeded 2011/10/19:01:30:52 Grace GRACE-HP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/19:01:31:01 Grace GRACE-HP Install Autodesk Material Library 2012 Succeeded 2011/10/19:01:31:01 Grace GRACE-HP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/19:01:31:22 Grace GRACE-HP Install Autodesk Material Library 2012 - Low Resolution Succeeded 2011/10/19:01:31:22 Grace GRACE-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Grace\AppData\Local\Temp\vcredist_x86_2005.log"" " 2011/10/19:01:31:29 Grace GRACE-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2011/10/19:01:31:29 Grace GRACE-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/19:01:31:34 Grace GRACE-HP Install Autodesk Content Service Succeeded 2011/10/19:01:31:35 Grace GRACE-HP Installing AutoCAD® Architecture 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\x64\en-us\ACA\ACA.mst;C:\Users\Grace\AppData\Local\Temp\_AI72AF.tmp\x64\ACA\ACA-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Architecture 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/19:01:31:35 Grace GRACE-HP Install AutoCAD® Architecture 2012 Failed Installation aborted, Result=1639 2011/10/19:01:31:42 Grace GRACE-HP Rollback Autodesk Content Service Succeeded 2011/10/19:01:31:42 Grace GRACE-HP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2011/10/19:01:31:52 Grace GRACE-HP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2011/10/19:01:32:04 Grace GRACE-HP Rollback Autodesk Material Library 2012 Succeeded 2011/10/19:01:32:06 Grace GRACE-HP Rollback FaroSDK Succeeded 2011/10/19:01:32:06 Grace GRACE-HP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
The installation stopped in the middle. Installation was failed.
Does anyone know solution to this? Can anyone please direct me please?
