Installation & Licensing
2918 Views, 3 Replies
Configure ADSKFLEX.opt
Hi everyone, i need to create some rules for user access to network license. i need to reserve some, assign license to a group etc.
I now that a ADSKFLEX.opt file can be created and configurated to do that, but how??? anyone have an explanation of how to configure an .opt file?
Thanks.
PD: In spanish better
3 REPLIES 3
TravisNave
Yes. I have set up groups in mine and reserved licenses. Pretty easy. Just follow the instructions in your NLM docs folder or from the following website:
http://www.macrovision.com/pdfs/flexlm_licensing_end_user_guide.pdf
If you need help beyond that, let me know.
Autodesk Forums:
thanks for the help.
I found in Autodesk this instructions about how to configurate a .opt file
Controlling network license access using an options file
Published date: 2006-06-21
Applies to:
AutoCAD® 2006
Issue
You would like to know how to control network license access using an options file with the FLEXlm or FLEXnet network license managers.
Solution
Access to licenses is controlled with a FLEXlm® options file that is configured with the settings you want to use. The options file is an optional component of the Flex license management system and is not required for normal license operation.
Creating the options file
1. Create a new text file named ADSKFLEX.OPT. It is strongly recommended that you only use a plain text editor, such as Notepad, for editing options files.
2. Place this file in the same directory as your Autodesk license file.
3. Perform a ReRead License File operation from the Start/Stop/ReRead tab in LMTOOLS.
4. Examine the debug log file to confirm that your options file changes have been implemented by the license manager.
Note: The examples in this document are intended to serve as samples only. Many options file commands, such as INCLUDE/EXCLUDE, are mutually exclusive. When you use these types of commands you should make sure that the syntax is correct.
Entering comments in the options file
All syntax following a number sign (#) will be ignored by the license manager.
An example of an options file comment is shown below.
#This is a comment
Defining groups
You can define groups using the Windows login name or the computer name. Note: Computer names and user names are case sensitive.
GROUP [groupname] [user1] [user2] [user3]
HOST_GROUP [groupname] [computername1] [computername2] [computername3]
The following example defines a group called EngineeringGroup for three users:
GROUP EngineeringGroup smithj jonesb whitef
The following example defines a group called DraftingDept with three computers:
HOST_GROUP DraftingDept computer1 computer2 computer3
Disabling case sensitivity for user and computer names
You can enable/disable case sensitivity for user names and computer names when using the GROUP or HOST_GROUP commands.
The following example disables case sensitivity for user and computer names:
GROUPCASEINSENSITIVE ON
The following example does not disable case sensitivity for user and computer names:
GROUPCASEINSENSITIVE OFF
Defining project association
Specific computers can be defined as part of a project by configuring an environment variable on those client machines. This project designation can then be used to control license access in the options file. Note: The project environment variable is an optional component and is not required when you define groups directly in the options file.
To designate a computer as a member of a project
1. On the Start menu (Windows), click Settings > Control Panel.
2. In Control Panel, double-click System.
3. In the System properties dialog box, click the Advanced tab.
4. On the Advanced tab, click Environment Variables.
5. Under System Variables, click New.
6. In the New System Variable dialog box, enter LM_PROJECT for the Variable name and the project name for the Variable value.
7. Click OK to close each dialog box.
Your project is now defined and you do not have to reboot the computer for these settings to take effect.
Reserving licenses
You can reserve a specific count of licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive).
RESERVE [count] [productfeature] [type] [name]
The following examples reserve either 1 or 5 AutoCAD® 2006 licenses for a variety of types:
RESERVE 1 48800ACD_2006_0F USER smithj
RESERVE 1 48800ACD_2006_0F HOST computer1
RESERVE 5 48800ACD_2006_0F GROUP EngineeringGroup
RESERVE 5 48800ACD_2006_0F HOST_GROUP DraftingDept
RESERVE 1 48800ACD_2006_0F INTERNET 192.168.0.100
RESERVE 5 48800ACD_2006_0F INTERNET 192.168.0.*
RESERVE 5 48800ACD_2006_0F PROJECT CivilProject
Restricting maximum license usage
You can limit usage of specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive).
MAX [count] [productfeature] [type] [name]
The following examples set a limit of either 1 or 5 AutoCAD 2006 licenses for a variety of types:
MAX 1 48800ACD_2006_0F USER smithj
MAX 1 48800ACD_2006_0F HOST computer1
MAX 5 48800ACD_2006_0F GROUP EngineeringGroup
MAX 5 48800ACD_2006_0F HOST_GROUP DraftingDept
MAX 1 48800ACD_2006_0F INTERNET 192.168.0.100
MAX 5 48800ACD_2006_0F INTERNET 192.168.0.*
MAX 5 48800ACD_2006_0F PROJECT CivilProject
Excluding license usage
You can block access to specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive). Note: Any users, hosts or IP addresses not explicitly excluded will continue to have access to these licenses.
EXCLUDE [productfeature] [type] [name]
The following examples block access to AutoCAD 2006 licenses for a variety of types:
EXCLUDE 48800ACD_2006_0F USER smithj
EXCLUDE 48800ACD_2006_0F HOST computer1
EXCLUDE 48800ACD_2006_0F GROUP EngineeringGroup
EXCLUDE 48800ACD_2006_0F HOST_GROUP DraftingDept
EXCLUDE 48800ACD_2006_0F INTERNET 192.168.0.100
EXCLUDE 48800ACD_2006_0F INTERNET 192.168.0.*
EXCLUDE 48800ACD_2006_0F PROJECT CivilProject
Including license usage
You can provide access to specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive). Note: Any users, hosts or IP addresses not explicitly included will not have access to the specified licenses. If you want to block license usage for only a few users you should consider using the EXCLUDE syntax.
INCLUDE [productfeature] [type] [name]
The following examples provide access to AutoCAD 2006 licenses for the specified type only:
INCLUDE 48800ACD_2006_0F USER smithj
INCLUDE 48800ACD_2006_0F HOST computer1
INCLUDE 48800ACD_2006_0F GROUP EngineeringGroup
INCLUDE 48800ACD_2006_0F HOST_GROUP DraftingDept
INCLUDE 48800ACD_2006_0F INTERNET 192.168.0.100
INCLUDE 48800ACD_2006_0F INTERNET 192.168.0.*
INCLUDE 48800ACD_2006_0F PROJECT CivilProject
Setting license inactivity timeout
You can configure the license manager to automatically reclaim inactive licenses after a specified time. Inactivity is defined as an idle product with no commands issued in the specified time. Users will be given the option to save their current drawing if a license is revoked by the license manager for inactivity. Note: Time is specified in seconds and the lowest acceptable value for these options is 900 seconds (15 minutes).
TIMEOUT [productfeature] [seconds]
TIMEOUTALL [seconds]
The following examples set inactivity timeouts of 30 minutes for AutoCAD 2006 and all respective products:
TIMEOUT 48800ACD_2006_0F 1800
TIMEOUTALL 1800
Report log creation
You can configure the creation of a report log (RL) file for use with the SAMreport™ or SAMreport™-lite usage reporting tools. For more information about configuring SAMReport-Lite, you should refer to the related documentation.
Note: The plus sign (+) preceding the report log file path indicates that the license manager should append to the report log instead of overwriting it. Also, the path for the report log should not contain spaces and must already exist (the license manager will not create this location for you). The license manager will create the report log file.
REPORTLOG +
The following example defines a report log file to be created in a specific location:
REPORTLOG +C:\Reports\MyServer.rl
Controlling license borrowing
Several options file commands control license borrowing for specified licenses.
Maintaining licenses
You can specify a number of specific licenses that cannot be borrowed.
BORROW_LOWWATER [productfeature] [count]
The following example blocks license borrowing for 5 AutoCAD 2006 licenses:
BORROW_LOWWATER 48800ACD_2006_0F 5
Setting the borrow period
You can specify the maximum duration of time that a specific license can be borrowed for in hours. Note: This value cannot be above the maximum borrow period specified by Autodesk in the product license file.
MAX_BORROW_HOURS [productfeature] [hours]
The following example limits license borrowing of AutoCAD 2006 licenses to 3 days:
MAX_BORROW_HOURS 48800ACD_2006_0F 72
Excluding license borrowing
You can block the ability to borrow specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive). Note: Any users, hosts or IP addresses not explicitly excluded will continue to have the ability to borrow licenses.
EXCLUDE_BORROW [productfeature] [type] [name]
The following examples block borrowing of AutoCAD 2006 licenses for a variety of types:
EXCLUDE_BORROW 48800ACD_2006_0F USER smithj
EXCLUDE_BORROW 48800ACD_2006_0F HOST computer1
EXCLUDE_BORROW 48800ACD_2006_0F GROUP EngineeringGroup
EXCLUDE_BORROW 48800ACD_2006_0F HOST_GROUP DraftingDept
EXCLUDE_BORROW 48800ACD_2006_0F INTERNET 192.168.0.100
EXCLUDE_BORROW 48800ACD_2006_0F INTERNET 192.168.0.*
EXCLUDE_BORROW 48800ACD_2006_0F PROJECT CivilProject
Including license borrowing
You can provide the ability to borrow specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT variable association (computer names and user names are case sensitive).
Note: Any users, hosts or IP addresses not explicitly included will not have the ability to borrow the specified licenses. If you want to block license borrowing for only a few users, you should consider using the EXCLUDE_BORROW syntax above.
INCLUDE_BORROW [productfeature] [type] [name]
The following examples allow borrowing of AutoCAD 2006 licenses for the specified type only:
INCLUDE_BORROW 48800ACD_2006_0F USER smithj
INCLUDE_BORROW 48800ACD_2006_0F HOST computer1
INCLUDE_BORROW 48800ACD_2006_0F GROUP EngineeringGroup
INCLUDE_BORROW 48800ACD_2006_0F HOST_GROUP DraftingDept
INCLUDE_BORROW 48800ACD_2006_0F INTERNET 192.168.0.100
INCLUDE_BORROW 48800ACD_2006_0F INTERNET 192.168.0.*
INCLUDE_BORROW 48800ACD_2006_0F PROJECT CivilProject
You should just look at
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Our blog on software license management - http://blog.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
Administrator Productivity
