you might also use the login script to set the environment variable.
J.
wrote in message news:6335425@discussion.autodesk.com...
Hi, i'm seeking some advice if anyone can help?
Our company is adopting a global network user license strategy to
consolidate all of our Autodesk licensed products. As the new deployment
images have already been created by another team (pointing to an old lic
server) Im thinking to use a custom *.ADM GPO template to change the XP Pro
clients system environment variable to point to the new list of distributed
primary license servers i.e. @server1;@server2;@server3.
The other alternative maybe to distribute a reg file to all the XP clients
via SMS, making the same Env_Var change as above.
What is the recommended solution\best practice for making these client side
changes??
Thanks in advance
Lee
