• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    jasonlester
    Re: Compatible Mechanical Desktop 2009 for Inventor 2010
    05-11-2011 07:03 PM in reply to: TravisNave
    I have and older version of Maechanical Desktop. (release 4) We are a small company (8 empolyees) We use autoCAD maybe a couple times a year. Currently it is running on an old windows 98 machine. I recently got a new laptop and was aslo told about running older programs in windows 7 My new machine is Win 7 Pro 64 bit. I get anerror about it being uncompatable because of the 64 bit thing. Is there a way to make it load? Like I said we are small and cannot really justify an upgrade with the amount we use it.
    Please use plain text.
    *Expert Elite*
    TravisNave
    05-11-2011 08:05 PM in reply to: avto
    No, Windows 7 does not offer any support for 16-bit applications. You might have luck using the Windows XP Virtual Console from Microsoft.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    jasonlester
    05-12-2011 11:37 AM in reply to: TravisNave
    Yep that is exactly what I ended up doing. Windows XP mode and install under that. All up and running great. Thanks Jason
    *Expert Elite*
    TravisNave
    05-12-2011 02:35 PM in reply to: jasonlester
    Excellent!  Glad you are up and running.
    Travis Nave
    Distinguished Contributor
    05-23-2011 08:58 AM in reply to: avto
    Hi, another question about MDT2009 and Inventor 2011 this time. How can we activate it. My client asked Autodesk activation service and they tell them that he can't activate with an Inventor 2011 key. The fact is that this customer precisely chose Inventor in order to keep its old design and migrate them to Inventor 2011. It's working (I know this because on my computer I activated MDT 2009 a long time ago and I can still migrate datas to Inventor 2011), but for new users it seems impossible. How can he activate his licence legally ?
    *Expert Elite*
    TravisNave
    05-23-2011 09:03 AM in reply to: aguitton116
    He will need to contact Autodesk for a prior use license for MDT 2009 under Subscription.
    Travis Nave
    New Member
    09-25-2012 04:12 PM in reply to: avto
    I already download this software still I'm not able to install it on windows 7 help please :smileysad:
    philip.s
    09-25-2012 04:24 PM in reply to: danielolvera
    Hi Daniel,
    What sort of install fail are you getting? MDT 2009 is not compatible to run on Windows 7 per the system requirements. Have you tried in XP / Compatibility mode?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    09-25-2012 04:39 PM in reply to: philip.s
    yes I already try the xp compatibility mode and also the vista compatibility in vain, the error happens in the end while installing the mechanical desktop, on the log file generated i found this: Install??? Autodesk Mechanical Desktop 2009??? Failed??? Installation aborted, Result=1603 ? DI Luis Daniel Olvera Alvarez Dise?o Neko S.A. de C.V. ? Altata #51-402 Col. Condesa Del. Cuauhtemoc CP 06100 M?xico DF Tel/Fax: 01 (55)?52773703 M?vil: 044 5516455275 E-mail: danielolvera@nekomexico.com Website:www.nekomexico.com Facebook: www.facebook.com/nekomexico Twiter: http://twitter.com/nekomexico
