Installation & Licensing
Communicator 2013 silent installation fails
2 REPLIES 2
499 Views, 2 Replies
I noticed that AMC2013 is now a single MSI file, which is good.
On the contrary the installation fails if run through MSIEXEC from a network drive where we have copied the contents of the DVD onto.
The log file of the installation is attached.
The command line used is: MsiExec.exe /passive /norestart /log "%TMP%\MFcommunicator2013.log" /i "U:\Moldflow\2013_Basis_Synergy32\x86\amc\amc.msi" ALLUSERS=1 ADDLOCAL=all
Thanks in advance for any light on this.
2 REPLIES 2
TravisNave
Error 1606. Could not access network location \Setup
Make sure that you have full admin read/write privileges to your folder.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I do have full administrative rights to the folder, since I am using the domain administrator account.
I just think that the setup still thinks it is run from a DVD, but it is actually on a network drive.
The root folder is "U:\Moldflow\2013_Basis_Synergy32" and not "D:\" as the setup seems to expect.
So the path returned is "U:\Setup", whereas it should be
"U:\Moldflow\2013_Basis_Synergy32\Setup".
I think that the installer is badly written witht oo many assumptions in mind.
Administrator Productivity
