I've been getting an error when tgrying to use "Install Now" option on Maya 2013. I've take a screenshot of it. Could anyone tell me what to do? I'm pretty green when it comes to network erorrs or any kind...
http://oi46.tinypic.com/30cbnrn.jpg
Thank you!
I hope this is the right place to ask. Google brought me here when I tried to google a solution to this problem, but I found none.
Solved by camilo.lemos. Go to Solution.
Solved by jessica.t. Go to Solution.
Solved by philip.s. Go to Solution.
Hi @ChaosCat and welcome to the Autodesk Community!
Have you tried changing your download method? If you try that and the problem persists please try these steps to help fix the issue:
Please reply to this post with any other questions or concerns. Thanks!
When I try to get maya, I get this error when using the Install Now option:
I'm not really sure how to fix this
I got newest .NET framework, I opened ports 80 and 443 in my firewall.
Now i try to directly install Inventor 2015 - i get connection failure, download - too. I even try to browser download it - 3 times it stopped at 2GB and didnt want to go further. What else can I do ?
Hello @iPr0xyyMC!
Outside of the recommendations listed on the Communication Failure warning screen, were you able to try Jessica's suggestions from the above post (also copied here for your convenience)? The simplest workaround is typically to utilize a different download method, specifically Browser Download, which can also be accessed from the Autodesk Virtual Agent.
I am a student and downloaded Maya student's version but have error keep showing "Communication Failure Error with installation".
please see attached print-screen and tell me what to do. Thanks,
Josephat
Hello Josephat,
Did you try the suggestions that mentioned in the above postings?
Hi Philip,
I have Disable UAC and delete cookies, temporary internet files, and history. Then downloaded Autodesk Maya 1.8GB file size, the above result is all I got.
Please instruct me further. Thanks!
Hi Kenny,
It looks like you haven't download pt.2 yet which is why you are receiving the missing file error. You can do so via the Autodesk Virtual Agent linked here.
Please let us know if that works!
I've downloaded the pt.2 and same error on the previous print-screen occured.
Please advise where to move the pt.2 before installation or which of pt.1 and pt.2 do I install first.
My OS is Win 7 64Bit and not Mac
Hi @kenny2g ,
Please, download both parts from the Virtual Agent. Once fully downloaded, double-click on Part 1 and the installation should proceed normally.
Make sure your firewall and anti-virus programs are disabled during the download.
I hope this helps!
Hi Camilo,
I have carried your task but didn't work. I had online chat Norton which they tried their best but detected that "ntxpiinst.exe" is affected. Told me to contact Autodesk and in form them that the installation file have virus ntxpiinst.exe. As Norton has detected this file as a threat you (me) can contact Autodesk MAya and let them know that Norton has detected a threat about Autodesk MAya file.
Hi Camilo,
I am still waiting to hear from you regarding the affected files and reply from Maya team as you said.
I can forward you more print-screen if you give me email address or I can sent it here if you want.
Yes Camilo,
I have been able to install Maya Pt.1 in my computer - up running.
Please confirm if Maya Pt.2 still needed to be installed because after insighting the key [OK] to the next step but the <Install> button not active as I hover my mouse over. See attached.
Thanks very much!
hello, new and im been trying to download this for school student version
i did the whole port thing, and then turned off my windows smartscreen, and and i got it to go, but as it asks me where to put it i hit ok and then i get this.
http://gyazo.com/5da7355f8d358de8a8525eab42f09188
not sure what im doing wrong? for it to do that.
I do have similar error from the begining until I seek help from the autodesk experts, I was able to get it right.
NOW delete all the download files and start afresh by downloading from Virtual Agent and start new download on the link provided.
NOTE: This instruction is for Autodesk Maya only.
Make sure you download both two files Part.1 and Part.2
When you finished downloading them, double click first Part.1 to resume installation and you will be prompt to create folder where to extract your files. After that Maya installation will start while you follow the steps.
Good luck
i see that athere are two parts for maya 2015, but my class needs 2014.
Idk if i can use 2015 for my class and if it will work properly with the 2014. since thats the one we have on our school computers.
