Installation & Licensing
philip.s
Message 21 of 99 (4,396 Views)
Re: Communication Failure Error with installation
05-08-2013 01:35 PM in reply to: mweiss34
Hello Edward,
The alternative in this case would be to download the software via an alternative method, specifically Browser Download.
If you're downloading from an Autodesk portal where this is not an available option, specifically as a trial, you can find most current + previous version download links via Matt, our Virtual Assistant.
Philip Schmelzer
Active Member
mweiss34
Message 22 of 99 (4,399 Views)
05-08-2013 02:24 PM in reply to: philip.s
I figured it out.  I'm downloaded and then I'll see if it works.
Active Member
mweiss34
Message 23 of 99 (4,394 Views)
05-08-2013 03:23 PM in reply to: philip.s
I installed the 30 day trial from your website and I can't even open nothing.  I get this error message see attachment
Employee
ankushved
Message 24 of 99 (4,382 Views)
05-08-2013 08:07 PM in reply to: cobrien_obfa
Hi Ciaran,
Are you still facing problem with Install Now? Can you check my private message? Thanks.
Thanks & Regards,
Ankush Ved
Member
wally-james
Message 25 of 99 (4,379 Views)
05-08-2013 09:20 PM in reply to: varieth
I have been closely watching this thread for quiet sometime cause i have been struggling to download the ''install now'' version.  I have been hesitant to reply to the thread as i was waiting for an eventual ''download now'' option, but it seems that option would not be coming anytime soon.
I have tried all these options mentioned in the thread and i am still anxious to try out this new revit.
help will be greatly appreciated
Wal
philip.s
Message 26 of 99 (4,340 Views)
05-09-2013 04:17 PM in reply to: wally-james
Hi Wally,
Confirming that Revit 2014 direct browser download links are now available in Matt, our Virtual Assistant!
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product -> Autodesk Revit Products -> Autodesk Revit.
Philip Schmelzer
Eduardo2012
Message 27 of 99 (4,280 Views)
05-12-2013 06:01 AM in reply to: varieth
I downloaded Revit 2014 trial version. Same communication error as described in this post. Tried in 3 different computers with same results. Disabled firewall, same results. Deleted the .exe file, downloaded again 3 times with same results. Tried in Windows 7 ultimate and Windows 8 in another computer.
Other posts suggest opening ports (what is that and how is it done????) and there's one post saying that an email client solves the problem. What does this mean? I use outlook here, I would think that's an email client.......and what in the world does that have to do with this issue?
This is all very strange and it seems there's no convincing answer for this yet. I hope to find the solution
philip.s
Message 28 of 99 (4,272 Views)
05-12-2013 09:45 AM in reply to: Eduardo2012
Sorry to hear that you're having issues Eduardo.
Instead of troubleshooting the communication errors which are typically difficult to pinpoint, the simplest workaround is to obtain the necessary browser download links from Matt, our Virtual Assistant.
Instructions from Matt: Download and Installation -> Software Download Links -> I need to redownload my product -> Autodesk Revit Products -> Autodesk Revit.
Please let us know if you have any additional questions, concerns, or issues!
Philip Schmelzer
Active Member
splaw
Message 29 of 99 (3,937 Views)
06-04-2013 06:26 PM in reply to: philip.s
I am having the same problem. Seems like the new install method is not working. Have been trying it for more than a a month .This download method should be remove and replaced immediately. It is causing a lot of wasted time and frustration.Obviously the software download method has not been tested properly.  The  web download should be posted to the main download site.
It has not been more than 2 months and it is still not fixed ?  Now we have to google to find out how to solve this problem ? Autodesk please get your act together !
Employee
ankushved
Message 30 of 99 (3,932 Views)
06-04-2013 07:54 PM in reply to: splaw
When you click on Install Now button and a small Setup.exe starts getting downloaded then do not click anywhere on the web page,  do not refresh it and do not close it. Installer needs some data for the product which you have selected to Install, so you need to wait on that web page.
Once the <...>_Setup.exe is downloaded, then click on it and wait for the installer to launch. Once the installer is launched, then you can close/refresh/click anywhere on the web page.
Please try these steps and send me a Private Message in case it still doesnt work.
Thanks for your patience.
Thanks & Regards,
Ankush Ved
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
