• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Re: Communication Failure Error with installation
    12-21-2012 12:10 AM in reply to: philip.s
    Thank tou Phil, I have done that and successfully installed Maya. Thanks again.
    Please use plain text.
    New Member
    02-15-2013 12:42 PM in reply to: philip.s
    I'm encountering the same issue while trying to download the Student Version of Maya 2013. I've tried Install Now and Download Now and neither work. Install now just gives me a file that, when run, only gives me a Communication Error. I tried changing the ports and I even turned off my firewall to try that. When I click Download Now it only gives me the install file for the Autodesk Download Manager, while has already been installed. When I run the DLM a download does not start like the website and all resources I can find suggest. As previously mentioned, I had a bunch of files that had accumulated from the multiple attempts, I deleted those and I'm still encountering this issue. I restarted my computer and repeated everything mentioned, to no avail. Any suggestions?
    Member
    02-16-2013 12:31 AM in reply to: deanjs88
    Delete all file you can find related to Maya, then try the browser download option. Keep in mind that it is a different file than the ones you have downloaded previously. That is what worked for me.
    New Member
    04-22-2013 07:03 AM in reply to: varieth
    Hi All, I have been having the same problem trying to download Building Design Suite 2014. I don't have access to the Firewall, so would like to use the Browser download - eh - where do you go for that.
    The webpage does not appear to allow it.
    Any quick guidance much appreciated.
    Ciaran
    philip.s
    04-22-2013 04:19 PM in reply to: cobrien_obfa
    Hello Ciaran,
    As the 2014 suite browser download links are not yet available on Matt, our Virtual Assistant (should be within the next couple of days), I'll send you a Private Message (little envelope next to your profile name when signed in) with the corresponding timed links.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    04-26-2013 10:46 AM in reply to: philip.s
    I have this message in the attachments when i try to install revit 2014 free trial.
    what i can do for this?
    philip.s
    04-26-2013 03:32 PM in reply to: ayman_hakam
    Welcome to the community Ayman!
    Take a look at the following Install Now troubleshooting suggestions and let us know if you're able to resolve the issue.
    Philip Schmelzer
    TW | PI | YT | BLOG
    Active Member
    05-07-2013 06:54 PM in reply to: varieth
    I'm having the same problem I disable the firewall and tried the advanced settings like discussed.  No luck.  What's this alternative download.  I don't understand
    Employee
    ankushved
    05-07-2013 09:00 PM in reply to: mweiss34
    Do not close or refresh the web page once you click Install Now, wait for the <abc>_Setup.exe to get downloaded. Once it downloads, run it. Wait for the main installer screen to appear. Hopefully, this should solve the problem.
    Thanks & Regards,
    Ankush Ved
    Active Member
    05-08-2013 10:29 AM in reply to: ankushved
    Still not working again I double click on setup.exe.  Windows wants to makes sure I want to install this I say yes.  Autodesk AutoCAD 2014 screen pops up and saids initizing and then I get the communication failure error.  I can't even download the free trail demo from you website because I get a network error from that to.
