Installation & Licensing
Message 1 of 12
mikeZapp
1321 Views, 11 Replies
Co-exist
Can AIP and AIS co-exist on the same machine? We have floaters and would like to be able to share the Pro when necessary.
During install of the Pro software the deployment stops and exits. If I check in non-silent mode I see that the installer states that a later version is already installed.
11 REPLIES 11
Message 2 of 12
TravisNave
in reply to: mikeZapp
No.  You should only install AIP.  It can pull an AIS license and will only pull the AIP licenses when using a pro module or when necessary.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 12
mikeZapp
in reply to: TravisNave
I guess I only need to uninstall the Inventor portion?
Message 4 of 12
DarrenP
its better to uninstall everything
DarrenP
Message 5 of 12
mikeZapp
in reply to: DarrenP
Here is the dilema. Let's say that I have twenty users; five users have a possible need to borrow 3 AIP licenses...all users require AutoCAD.
Will the license server borrow the AutoCAD features from any available seat (17 AIS, 3 AIP)? I need to have all twenty AutoCAD seats available at all times.
Message 6 of 12
DarrenP
depends
do you have separate licenses of just autocad in your license file?
DarrenP
Message 7 of 12
TravisNave
AutoCAD (assuming from the Mechanical install of the Inventor Suite) will cascade to the available license when necessary.  When a single user launches AIP and AutoCAD, the user will still only use one license total as the programs are part of the same suite, thus share the license.
I would suspect the only issue you will have is not running out of AutoCAD licenses, it will be running out of AIP licenses.  When your three AIP seats are used by 3 users, your 4th and 5th AIP users will have to wait for a seat to free up.  They'd still be able to launch AIS or AutoCAD, however.
Autodesk Forums:
Message 8 of 12
mikeZapp
TravisNave
I was thinking that what you have discribed woud be the case. The AIP would only be required part of the time by the 5 users, three would have to be full time and swap out if on other required AIP usage
Message 9 of 12
mikeZapp
DarrenP
The licenses are budled with each suite. I use to have all twenty AIS seats but, we recently upgraded 3 to AIP.
Message 10 of 12
DarrenP
then what travis said is correct then
you may run out of AIP licenses at some point
DarrenP
Message 11 of 12
mikeZapp
Thanks to All. I wil be attemping the install tomorrow.
Message 12 of 12
TravisNave
Excellent.  Let us know how it goes.
Autodesk Forums:
Administrator Productivity
