Problem solved, it was one of my routines.
(vl-load-com)
(defun set_psty (/ output)
(setq output
(vla-get-output (vla-get-preferences (vlax-get-acad-object))))
(vla-put-defaultoutputdevice output "67B2OceTBON.pc3")
(vla-put-plotpolicy output "0")
(vla-put-defaultplotstyletable output "psands.stb")
(vla-put-defaultplotstyleforlayer output "black")
I was using it to set a drawing to Named Styles using the psands.stb file. I
guess there is an issue I'm over looking.
Thomas Maleski
"Thomas E. Maleski" wrote in message
news:698ACE7C20E315C890C84EAF4E9B2DDD@in.WebX.maYIadrTaRb...
> fine. No error message.>>
> No. I can't open the file in a client deployment of ADT3.3. I can open the
> file in a network version of ADT fine, save it and then it opens fine in
the
> client deployment. I just asked another department to try and open the
file,
> also a client install, and they can open it fine. I need to check some of
my
> code that I have run at startup. I know I'm having a problem with my ACAD
> env settings. I report back later.
> "jason martin [Autodesk]" wrote in message
> news:9FE0A912B129AFA7F73AE09106DFF27D@in.WebX.maYIadrTaRb...
> > Hi Thomas -
> > That sounds ... umm ... interesting.
> > Just so I have this straight. You have some R14 drawings that have
xrefs.
> > If you open the drawing in a client deployment of ADT3.3, the files open
> > If you open the drawing in a client deployment of ABx (on top of the
same
> > client deploy of ADT3.3) you get the "Severe error"?
> > What happens after the Severe error?
> > jason martin
> > Autodesk
> > news:76AF4428A78270007A89E67C90BFDD3B@in.WebX.maYIadrTaRb...
> > > We are currently using a client install of ADT/ABE2/ABM2. When opening
> > > drawings created in R14 and that contain xrefs, we receive an "AutoCAD
> > > Severe Error, file not found" dialog box. If I were to open the file
in
> a
> > > Network install of ADT the file opens up fine. Has anyone receive this
> > error
> > > message before? Once the file is opened in the Network ADT and saved
the
> > > file is fine.
> > > Thomas Maleski
