Hi, I have the error [1.5.-59] when I try to start Autocad MAP 3D 2008 in the client machine.
The Network License Mangager is updated to 11.7 on win2003 virtual machine
Do you have a solution for this?
Fabrizio
Log:
10:47:51 (lmgrd) -----------------------------------------------
10:47:51 (lmgrd) Please Note:
10:47:51 (lmgrd)
10:47:51 (lmgrd) This log is intended for debug purposes only.
10:47:51 (lmgrd) In order to capture accurate license
10:47:51 (lmgrd) usage data into an organized repository,
10:47:51 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
10:47:51 (lmgrd) software license administration solution,
10:47:51 (lmgrd) FLEXnet Manager, to readily gain visibility
10:47:51 (lmgrd) into license usage data and to create
10:47:51 (lmgrd) insightful reports on critical information like
10:47:51 (lmgrd) license availability and usage. FLEXnet Manager
10:47:51 (lmgrd) can be fully automated to run these reports on
10:47:51 (lmgrd) schedule and can be used to track license
10:47:51 (lmgrd) servers and usage across a heterogeneous
10:47:51 (lmgrd) network of servers including Windows NT, Linux
10:47:51 (lmgrd) and UNIX. Contact Acresso Software Inc. at
10:47:51 (lmgrd) www.acresso.com for more details on how to
10:47:51 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:47:51 (lmgrd) for your enterprise.
10:47:51 (lmgrd)
10:47:51 (lmgrd)
10:47:51 (lmgrd)
10:47:51 (lmgrd) pid 3224
10:47:51 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:47:51 (lmgrd) Done rereading
10:47:51 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_n3) started on ps130-srv1 (IBM PC) (4/22/2010)
10:47:51 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
10:47:51 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:47:51 (lmgrd) World Wide Web: http://www.acresso.com
10:47:51 (lmgrd) License file(s): C:\Programmi\Autodesk Network License Manager\license.lic
10:47:51 (lmgrd) lmgrd tcp-port 27000
10:47:51 (lmgrd) Starting vendor daemons ...
10:47:51 (lmgrd) Starting vendor daemon at port 2080
10:47:51 (lmgrd) Using vendor daemon port 2080 specified in license file
10:47:51 (lmgrd) Started adskflex (pid 888)
10:47:51 (adskflex) Unable to initialize access to trusted storage: 1
10:47:51 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
10:47:51 (adskflex) Server started on ps130-srv1 for: 55900MAP_2008_0F
10:47:51 (adskflex) EXTERNAL FILTERS are OFF
10:47:51 (lmgrd) adskflex using TCP-port 2080
10:47:53 (lmgrd) Rereading license file... Requested from u33607@PS130-SRV1
10:47:53 (adskflex) TCP_NODELAY NOT enabled
10:47:53 (adskflex) Rereading license file...
10:47:53 (adskflex) Server started on ps130-srv1 for: 55900MAP_2008_0F
10:47:53 (adskflex) Updating feature 55900MAP_2008_0F
10:47:53 (adskflex) Rereading options file...
10:47:53 (adskflex) ...Finished rereading
10:47:53 (lmgrd) Done rereading
10:47:53 (lmgrd) ...Finished rereading
10:48:17 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:18 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:31 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:32 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:36 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:37 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:41 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:42 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:53 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:49:06 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
Status
Flexible License Manager status on Thu 4/22/2010 10:54
[Detecting lmgrd processes...]
License server status: 27000@ps130-srv1
License file(s) on ps130-srv1: C:\Programmi\Autodesk Network License Manager\license.lic:
ps130-srv1: license server UP (MASTER) v11.7
Vendor daemon status (on ps130-srv1):
adskflex: UP v11.7
Feature usage info:
Users of 55900MAP_2008_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Diagnostics
FLEXnet diagnostics on Thu 4/22/2010 10:54
License file: C:\Programmi\Autodesk Network License Manager\license.lic
"55900MAP_2008_0F" v1.000, vendor: adskflex
License server: ps130-srv1
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
