Installation & Licensing
395 Views, 1 Reply
Client Error [1.5.-59]
Hi, I have the error [1.5.-59] when I try to start Autocad MAP 3D 2008 in the client machine.
The Network License Mangager is updated to 11.7 on win2003 virtual machine
Do you have a solution for this?
Fabrizio
Log:
10:47:51 (lmgrd) -----------------------------------------------
10:47:51 (lmgrd) Please Note:
10:47:51 (lmgrd)
10:47:51 (lmgrd) This log is intended for debug purposes only.
10:47:51 (lmgrd) In order to capture accurate license
10:47:51 (lmgrd) usage data into an organized repository,
10:47:51 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
10:47:51 (lmgrd) software license administration solution,
10:47:51 (lmgrd) FLEXnet Manager, to readily gain visibility
10:47:51 (lmgrd) into license usage data and to create
10:47:51 (lmgrd) insightful reports on critical information like
10:47:51 (lmgrd) license availability and usage. FLEXnet Manager
10:47:51 (lmgrd) can be fully automated to run these reports on
10:47:51 (lmgrd) schedule and can be used to track license
10:47:51 (lmgrd) servers and usage across a heterogeneous
10:47:51 (lmgrd) network of servers including Windows NT, Linux
10:47:51 (lmgrd) and UNIX. Contact Acresso Software Inc. at
10:47:51 (lmgrd) www.acresso.com for more details on how to
10:47:51 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:47:51 (lmgrd) for your enterprise.
10:47:51 (lmgrd)
10:47:51 (lmgrd)
10:47:51 (lmgrd)
10:47:51 (lmgrd) pid 3224
10:47:51 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:47:51 (lmgrd) Done rereading
10:47:51 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_n3) started on ps130-srv1 (IBM PC) (4/22/2010)
10:47:51 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
10:47:51 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:47:51 (lmgrd) World Wide Web: http://www.acresso.com
10:47:51 (lmgrd) License file(s): C:\Programmi\Autodesk Network License Manager\license.lic
10:47:51 (lmgrd) lmgrd tcp-port 27000
10:47:51 (lmgrd) Starting vendor daemons ...
10:47:51 (lmgrd) Starting vendor daemon at port 2080
10:47:51 (lmgrd) Using vendor daemon port 2080 specified in license file
10:47:51 (lmgrd) Started adskflex (pid 888)
10:47:51 (adskflex) Unable to initialize access to trusted storage: 1
10:47:51 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
10:47:51 (adskflex) Server started on ps130-srv1 for: 55900MAP_2008_0F
10:47:51 (adskflex) EXTERNAL FILTERS are OFF
10:47:51 (lmgrd) adskflex using TCP-port 2080
10:47:53 (lmgrd) Rereading license file... Requested from u33607@PS130-SRV1
10:47:53 (adskflex) TCP_NODELAY NOT enabled
10:47:53 (adskflex) Rereading license file...
10:47:53 (adskflex) Server started on ps130-srv1 for: 55900MAP_2008_0F
10:47:53 (adskflex) Updating feature 55900MAP_2008_0F
10:47:53 (adskflex) Rereading options file...
10:47:53 (adskflex) ...Finished rereading
10:47:53 (lmgrd) Done rereading
10:47:53 (lmgrd) ...Finished rereading
10:48:17 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:18 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:31 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:32 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:36 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:37 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:41 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:48:42 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
10:48:53 (adskflex) OUT: "55900MAP_2008_0F" u33607@a3060022
10:49:06 (adskflex) IN: "55900MAP_2008_0F" u33607@a3060022
Status
Flexible License Manager status on Thu 4/22/2010 10:54
[Detecting lmgrd processes...]
License server status: 27000@ps130-srv1
License file(s) on ps130-srv1: C:\Programmi\Autodesk Network License Manager\license.lic:
ps130-srv1: license server UP (MASTER) v11.7
Vendor daemon status (on ps130-srv1):
adskflex: UP v11.7
Feature usage info:
Users of 55900MAP_2008_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Diagnostics
FLEXnet diagnostics on Thu 4/22/2010 10:54
License file: C:\Programmi\Autodesk Network License Manager\license.lic
"55900MAP_2008_0F" v1.000, vendor: adskflex
License server: ps130-srv1
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
1 REPLY 1
Antonio_Barroca
Hi Fabrizio ,
The error 1.5.-59 indicates a "message checksum failure".
This is a communication error between the server and the client.
Messages between client and server are encrypted and checked for security and integrity. The checksum will usually fail because of poor networking communications.
On other side please be aware that running the Network License Manager on virtual server platforms has not been tested; therefore, it is not supported by Autodesk.
Virtual server platforms and the Autodesk Network License Manager
Regards
Antonio Barroca
Autodesk Product Support
We appreciate your quick feedback on this forum!
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
Autodesk, Inc.
Administrator Productivity
