I tried to install Civil3d 2012 and it failed. the log file said unsupported net version. Do I just need to update the .net framework version or is it something else.
Solved by david.lau. Go to Solution.
You can manually install .NET. If you are on Windows 7, .NET is intregrated in the the operating system.
Can you attach a screen capture and the install log file?
