Installation & Licensing
Member
Message 1 of 6 (292 Views)
Accepted Solution
Civil3D Installation Failure
292 Views, 5 Replies
03-22-2013 07:17 PM
I've read some of the other threads, disabled my AV software, deleted my temp files.  Still didn't work.
Here's my installation log.
2013/3/22:19:57:31 Damien DAMIEN-LAPPY === Setup started on DAMIEN-LAPPY by Damien === 2013/3/22:19:57:31 Damien DAMIEN-LAPPY Launch 2013/3/22:19:57:52 Damien DAMIEN-LAPPY === Setup ended ===
2013/3/22:19:57:50 Damien DAMIEN-LAPPY === Setup started on DAMIEN-LAPPY by Damien === 2013/3/22:19:57:50 Damien DAMIEN-LAPPY Launch 2013/3/22:19:57:50 Damien DAMIEN-LAPPY Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S... 2013/3/22:19:57:51 Damien DAMIEN-LAPPY PageOpen LaunchDialog   2013/3/22:19:58:16 Damien DAMIEN-LAPPY PageOpen LicenseDialog   2013/3/22:19:58:35 Damien DAMIEN-LAPPY PageOpen ProductInfoDialog   2013/3/22:19:59:18 Damien DAMIEN-LAPPY PageOpen ProductSelectionDialog2   2013/3/22:19:59:28 Damien DAMIEN-LAPPY PageOpen FullProgressDialog   2013/3/22:19:59:28 Damien DAMIEN-LAPPY Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D... 2013/3/22:19:59:28 Damien DAMIEN-LAPPY Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/22:20:00:06 Damien DAMIEN-LAPPY Install DirectX Runtime Succeeded  2013/3/22:20:00:06 Damien DAMIEN-LAPPY Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:00:28 Damien DAMIEN-LAPPY Install FaroSDK Succeeded  2013/3/22:20:00:28 Damien DAMIEN-LAPPY Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:00:28 Damien DAMIEN-LAPPY Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:01:09 Damien DAMIEN-LAPPY Install Autodesk Material Library 2013 Succeeded  2013/3/22:20:01:09 Damien DAMIEN-LAPPY Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:01:09 Damien DAMIEN-LAPPY Installing Autodesk Material Library 2013 - Low Resolution:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:01:50 Damien DAMIEN-LAPPY Install Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/22:20:01:50 Damien DAMIEN-LAPPY Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD Civil 3D 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:07 Damien DAMIEN-LAPPY Install Autodesk Content Service Succeeded  2013/3/22:20:02:07 Damien DAMIEN-LAPPY Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:17 Damien DAMIEN-LAPPY Install Autodesk Content Service Language Pack Succeeded  2013/3/22:20:02:17 Damien DAMIEN-LAPPY Installing SQL Server CE 3.5 x86:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:26 Damien DAMIEN-LAPPY Install SQL Server CE 3.5 x86 Succeeded  2013/3/22:20:02:26 Damien DAMIEN-LAPPY Installing SQL Server CE 3.5 x64:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:31 Damien DAMIEN-LAPPY Install SQL Server CE 3.5 x64 Succeeded  2013/3/22:20:02:31 Damien DAMIEN-LAPPY Download Skipped VBPOWERPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V... 2013/3/22:20:02:31 Damien DAMIEN-LAPPY Installing Microsoft Visual Basic Power Packs 10.0: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Damien\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log 2013/3/22:20:02:36 Damien DAMIEN-LAPPY Install Microsoft Visual Basic Power Packs 10.0 Succeeded  2013/3/22:20:02:42 Damien DAMIEN-LAPPY Download Play C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:12:17 Damien DAMIEN-LAPPY Download Aborted C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:12:17 Damien DAMIEN-LAPPY Install AutoCAD Civil 3D 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/22:20:12:18 Damien DAMIEN-LAPPY Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619 2013/3/22:20:12:23 Damien DAMIEN-LAPPY Rollback SQL Server CE 3.5 x64 Succeeded  2013/3/22:20:12:29 Damien DAMIEN-LAPPY Rollback SQL Server CE 3.5 x86 Succeeded  2013/3/22:20:12:34 Damien DAMIEN-LAPPY Rollback Autodesk Content Service Language Pack Succeeded  2013/3/22:20:12:46 Damien DAMIEN-LAPPY Rollback Autodesk Content Service Succeeded  2013/3/22:20:13:13 Damien DAMIEN-LAPPY Rollback Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/22:20:13:52 Damien DAMIEN-LAPPY Rollback Autodesk Material Library 2013 Succeeded  2013/3/22:20:13:56 Damien DAMIEN-LAPPY Rollback FaroSDK Succeeded  2013/3/22:20:13:56 Damien DAMIEN-LAPPY Rollback DirectX Runtime Failed Failure is ignored, Result=1619
*Expert Elite*
TravisNave
Message 2 of 6 (239 Views)
Re: Civil3D Installation Failure
03-25-2013 08:55 AM in reply to: callmestick
The program is not finishing downloading.  This may be a problem with the student site.  You might try another computer or try it later to see if it works.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
Message 3 of 6 (236 Views)
03-25-2013 09:16 AM in reply to: callmestick
Oh, good to know.  We had internet problems this weekend and they came and fixed it yesterday so I will try again.
Thankyou.
Member
Message 4 of 6 (202 Views)
03-27-2013 05:56 AM in reply to: callmestick
I tried again last night both on a hard line and wireless and got to the exact same point and the download failed again.
If I have access to a CD, can I install with the CD using my student serial number and product key?
camilo.lemos
Message 5 of 6 (199 Views)
03-27-2013 06:16 AM in reply to: callmestick
Hi callmestick,
Yes, you can install the program from your CD and activate it with the product info you obtained from the Education Community.
Best regards,
Camilo Lemos
Member
Message 6 of 6 (196 Views)
03-27-2013 06:52 AM in reply to: camilo.lemos
Awsome, I'll just do that.   Thanks.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
