• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Civil 3D FATAL ERROR at startup
    128 Views, 2 Replies
    01-16-2013 08:32 AM
    We're loading Autocad Civil 3D 2013 (stand alone license) on a new computer.  It seems to install fine but on starting the program, we get a "FATAL ERROR;  unhandled 80000003h Exception at fdd83172h" message.
    We've done a clean uninstall / reinstall without success.
    The new computer is a DELL:
    Processors: 3rd Gen Intel® Core™ i5-3470 (Quad Core, 3.20GHz, 6MB w/HD2500 Graphics)
    Operating System: Windows 7 Professional, No Media, 64-bit, English
    OptiPlex 7010 SFF OptiPlex 7010 SFF w/ up to 90% Efficient Power Supply
    Memory: 8GB, NON-ECC, 1600MHZ DDR3,2DIMM
    Graphics Card: Intel Integrated Graphics,W/O
    Boot Hard Drives: 320GB 2.5 SATA 3.0Gb/s with 16MB DataBurst Cache™
    I'm wondering if the Integrated graphics card is the problem.  Has anyone run into this problem before?
    Please use plain text.
    TravisNave
    Re: Civil 3D FATAL ERROR at startup
    01-16-2013 10:34 AM in reply to: JimCunningham1600
    The video card could be problematic.  You might see if there is an updated driver, but those onboard cards are pretty weak for Autodesk applications.
    You might also consider reinstalling your .NET Framework as a lot of these issues are as a result of that.
    .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Product Support
    AlmasSuljevic
    01-22-2013 12:11 PM in reply to: JimCunningham1600
    Did any of the previous suggestiones regarding .NET help? Can you try launching AutoCAD by right-click on your desktop icon and choose "Run as Administrator"? Does that make any difference?
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
