neilyj (No connection with Autodesk other than using the products in the real world)
Here is an interesting workflow:
http://upandready.typepad.com/up_and_ready/2013/03/installing-language-packs-for-autocad.html
If you are on Subs, then on the Subs site hit the Language dropdown - don't know if David's language pack suggestion works as never had to try it. If neither work you'll just have to get to used to Elevation and Station but at least it'll be in metric units....!!!!
