Installation & Licensing
Valued Contributor
RandyBenson
Message 1 of 6 (329 Views)
Civil 3D 2013 Hotfix 2 x64 isn't.
329 Views, 5 Replies
12-05-2012 02:03 AM
Got an email from Autodesk titled: "HotFix Available for AutoCAD Civil 3D 2013"
Clicked on the Readme (Learn more...) link which should go to http://updatesdl.autodesk.com/updates/files/autocad_civil_3d_2013_hotfix_2.htm. The link is broken, but I searched for 'Hotfix 2' on the broken link page and found the hotfix page. It is at http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20384157&linkID=9240698.
There is an x32 version and an x64 version of the hotfix.
Having an x64 computer, and the x64 version of C3D 2013 sp1 installed, I clicked on the link to c3d2013_x64_hf2.1.exe.
It downloaded fine, but when run, a message box appears which states the following:
DarrenP
Message 2 of 6 (321 Views)
Re: Civil 3D 2013 Hotfix 2 x64 isn't.
12-05-2012 06:04 AM in reply to: RandyBenson
its because you have sp 1 installed
this includes hotfix 2.1
Valued Contributor
RandyBenson
Message 3 of 6 (312 Views)
12-05-2012 10:26 AM in reply to: DarrenP
Hm. I'd think that as much as C3D phones home, Autodesk CER would know that and would refrain from emailing me about available hotfixes that are rolled up into service packs I've already applied...
Thanks for clearing that up for me.
Valued Contributor
RandyBenson
Message 4 of 6 (311 Views)
12-05-2012 10:28 AM in reply to: DarrenP
Thanks. It would be good if Autdesk CEP had included that fact in the readme...
Valued Contributor
RandyBenson
Message 5 of 6 (310 Views)
Or the email.
TravisNave
Message 6 of 6 (302 Views)
12-05-2012 11:02 AM in reply to: RandyBenson
From the SP1 Readme:
This readme contains the latest information regarding the installation and use of this service pack. It is strongly recommended that you read this entire document before you apply this service pack to your product. AutoCAD Civil 3D 2013 Service Pack 1 contains the fixes included in AutoCAD 2013 Service Pack 1.1 and AutoCAD Map 3D 2013 Service Pack 1. This service pack includes all previous hotfixes for AutoCAD Civil 3D 2013 including Hot Fix 1, Hot Fix 2 and Hot Fix 2.1. Because AutoCAD Civil 3D is built on AutoCAD and AutoCAD Map 3D, it is recommended that you also review the AutoCAD and AutoCAD Map 3D readme files at the following locations. For reference, you should save these documents to your hard drive or print a copy.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
