Installation & Licensing
Active Contributor
tompkins
Message 1 of 8 (7,389 Views)
Civil 3D 2011 fails to install
7389 Views, 7 Replies
11-11-2010 07:21 AM
Hello all,
I am having trouble installing C3D 2011.  I get the following error message.
An errror occurred during the installation of assembly 'policy.1.1.FARO.LS,version="1.1.406.58",type="win32-policy",processorArchtecture="x86",publicKeyToken="1d23f5635ba800ab"'. Please refer to Help and Support for more information.
First I have installed in successfully on another machine in the office.  This is a stand alone install.  On research so far, I have
A)  looked at TS15149656 (which says turn off Norton AV during install).  I have PC Tools Spyware Doctor w/ AV and it is already turned off.
B)  Removed all of the dot net versions and reinstalled dot net using Microsoft tools and verified registry size limit.
 see http://forums.autodesk.com/t5/Installation-Licensing/Autocad-2011-Installation-trouble-error-1603/m-...
 and see http://support.microsoft.com/kb/923100/en-us
C)  Ran Microsoft Directx web installer to make sure i have the latest version.
Install logs:
2010/11/11:09:14:23 rtompkins HERMAN === Setup started on HERMAN by rtompkins ===
2010/11/11:09:16:48 rtompkins HERMAN Install DirectX 9.0 Runtime Succeeded
2010/11/11:09:22:08 rtompkins HERMAN Install FARO LS 1.1.406.58 Failed Installation aborted, Result=1603
2010/11/11:09:22:09 rtompkins HERMAN Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/11/11:09:22:15 rtompkins HERMAN === Setup ended ===
2010/11/11:09:14:23 rtompkins HERMAN === Setup started on HERMAN by rtompkins ===2010/11/11:09:16:48 rtompkins HERMAN Install DirectX 9.0 Runtime Succeeded 2010/11/11:09:22:08 rtompkins HERMAN Install FARO LS 1.1.406.58 Failed Installation aborted, Result=16032010/11/11:09:22:09 rtompkins HERMAN Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=16192010/11/11:09:14:23 rtompkins HERMAN === Setup started on HERMAN by rtompkins ===2010/11/11:09:16:48 rtompkins HERMAN Install DirectX 9.0 Runtime Succeeded 2010/11/11:09:22:08 rtompkins HERMAN Install FARO LS 1.1.406.58 Failed Installation aborted, Result=16032010/11/11:09:22:09 rtompkins HERMAN Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=16192010/11/11:09:22:15 rtompkins HERMAN === Setup ended ===
Randy
i am running dell precision t3400 xp sp3, 4G ram, current on all updates and drivers. Graphics card is Nvidia Quadro FX 570, drivers 6.05.26 (performance) and video 259.57 (6.14.5957)
Randy Tompkins, PSM
Degrove Surveyors
Product Support
hashim.mundol
Message 2 of 8 (7,363 Views)
Re: Civil 3D 2011 fails to install
11-11-2010 11:37 PM in reply to: tompkins
Do you have any other version of FARO LS installed; please check in add/remove program
if not
Please try to install as true administrator in Diagnostics mode.
http://usa.autodesk.com/getdoc/id=TS1054234
If this doesnt work, there should be a verbose log with %temp% directoy which would give more details on this error
please post the error parts here.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Active Contributor
tompkins
Message 3 of 8 (7,334 Views)
11-15-2010 04:52 AM in reply to: hashim.mundol
Hi Hashim,
I had a previously installation of C3d 2011 on my machine that had some issues due to a computer cleanup / registry cleaner program (Registry Mechanic) (not a good thing,it cleaned too much).  Anyway, I saw a post somewhere about uninstalling Faro LS if it was listed in Add/Remove Programs.  It was not.
I found a post at another site (not cad related) with the same issue.  Even though it was not installed, there is a folder in C:\Windows\WinSxS called x86_FARO.LS , just needed to delete that folder and C3D installed fine.
BTW, what is FARO LS for?
Randy Tompkins, PSM
Degrove Surveyors
Product Support
hashim.mundol
Message 4 of 8 (7,329 Views)
11-15-2010 04:55 AM in reply to: tompkins
hi
thanks for sharing the solution
you can read about FARO LS here
http://www.faro.com/usa/contentpages/colorscanner/
Hashim Mundol
Active Contributor
tompkins
Message 5 of 8 (7,324 Views)
11-15-2010 04:56 AM in reply to: hashim.mundol
Hashim,
Also wanted to say thanks for the quick reply(s) !!
Randy
Randy Tompkins, PSM
Degrove Surveyors
Product Support
hashim.mundol
Message 6 of 8 (7,297 Views)
11-16-2010 12:33 AM in reply to: tompkins
you're welcome.
It was great to see a good collaboration in fixing the issue.
Hashim Mundol
Dwayne.Poot
Message 7 of 8 (6,508 Views)
03-04-2011 08:09 AM in reply to: tompkins
Hi All;
   We have recently had similair reports of this issue/error that needed a bit more troubleshooting to resolve. In addition to the
C:\Windows\WinSxS\x86_FARO.LS_1d23f5635ba800ab... folder you may also have rename the below files/folders to work around this issue
C:\WINDOWS\WinSxS\Policies\x86_policy.1.1.FARO.LS_1d23f5635ba800ab_x-ww...
C:\WINDOWS\WinSxS\Manifests\x86_FARO.LS_1d23f5635ba800ab_1.1.406.58_x-ww_a175a29b.cat
C:\WINDOWS\WinSxS\Manifests\x86_FARO.LS_1d23f5635ba800ab_1.1.406.58_x-ww_a175a29b.Manifest
   Please try to rename the above files and try the installation again
dwayne
Dwayne Poot
Support Specialist
Product Support
New Member
maryamkonn
Message 8 of 8 (923 Views)
11-24-2013 10:27 PM in reply to: hashim.mundol
I have the same problem with installing AutoCad 13 and I recieved several times the Faro.LS error!
How is that possible to remove a whole folder: winsxs  from the computer which is a measurement source for 3D design?!?!...
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
