Installation & Licensing
Change SN on Network Install?
5 REPLIES 5
andrew.warren
502 Views, 5 Replies
On a network install you cannot go to About and then change the SN. Isn't their a way to edit the regestry or somehting to change it? We have a new IT guy and he acidently used the old SN to install a bunch of AutoCAD Electrical seats. I want to change all of them (one at a time I know) to the new SN. But I don't want to spend three weeks uninstalling and reinatalling them. We are talking potentually 50-75 workstations...
Andy Warren
BCDesign@bellsouth.net
5 REPLIES 5
DarrenP
in reply to: andrew.warren
the serial number gets pulled from the license file
during install it doesn't matter what serial number you use since its a network license
DarrenP
TravisNave
in reply to: DarrenP
Mark Darren's post as the solution, because he could not be more right.  The serial number for network products is irrelevent to the licensing.  For all intents and purposes, they could all have 000-00000000 and it would still work.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
DarrenP
you can change it through the registry
its under the hkey_local_machine/software/autodesk
but you don't really need to
DarrenP
andrew.warren
They hired me to help clean things up beacuse of a big LC todo. So I just want to be sure before I leave them be...
Andy Warren
DarrenP
you can run your license file through this website to get serial numbers from it: www.licenseparser.com
DarrenP
Administrator Productivity
