I got email about activation that i need to tell u reason why i need it...Well.. FORMAT. 🙂 So that's why. Can i activate my 3ds max now, please..?
Hi Studio,
I have already activated your Serial Number base on the information in Case 07493556. Activation Code was sent to your email address.
I will now also be closing case 07494054, which was automatically generated by the system.
Thank you!
I didn't have to even paste activation code. It's just work and its saying that this product is on subscription so everything is fine now?
Im changing my mind about autodesk help center. It's actually pretty good and fast!
Hi Studio,
Glad to hear you have the product up and running:) If the program is opening normally and it is saying that it's under subscription, this means that the activation worked.
Let us know if you need any further assistance!
CaseNo:07512284. this time..
I have hardware problem. Autodesk softwares are freezing my PC while starting. ;/ And nothing is helping.......
Hi Studio:
A new case has been created for you, 07514489. Our Technical Support Team will contact you directly regarding your concern.
Best Regards,
Arlin
