I have 54 AutoCAD MEP licenses 16 Revit Systems Series licenses. I recently hit my max of 54 AMEP, it was my understanding that in that event, it would pull a 'more valuable' Revit Systems license. But that did not happen, my users were just denied usage. In theory, 70 engineers should be able to request AMEP licenses at one time (54+16) assuming none are in Revit.
Below is a screenshot of our AutoCAD information as well as the latest license report confirming my theory and finally is our network license file.
*** Id really like to get the cascading working, hopefully without uninstall/reinstall of any software *** any help is greatly appreciated!
Dustin
PACKAGE 65100BLDSYS_F adskflex 1.000 COMPONENTS="85734BLDSYS_2012_0F \
85562BLDSYS_2011_0F 73000BLDSYS_2010_0F 59900BLDSYS_2009_0F" \
OPTIONS=SUITE SUPERSEDE ISSUED=27-Jun-2011 SIGN="0793 CAE4 \
A1FF C274 5AD7 F2E5 7884 71E3 1CD7 3741 A705 1C38 DC21 9D11 \
AB1C 1E2D 6EF2 ABB1 FC87 DA1E B2B4 FF1D 52F3 37A2 72ED 45D1 \
C65F D4A4 7616 141F" SIGN2="095E 3DB6 22A5 A2A1 C62C 280B 20D7 \
F04B 56FC 7346 36AF 999A C378 EB9C A122 0E96 9670 918A 99BA \
B632 7DD2 9B42 39AD 31E3 1ECE 2E6A 6796 A7FA 3E4C 05ED"
INCREMENT 65100BLDSYS_F adskflex 1.000 permanent 54 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
SUITE_DUP_GROUP=UHV ISSUED=27-Jun-2011 BORROW=4320 \
SN=xxx-xxxxxxxx SIGN="074B 8731 A9DB B13D 365C C332 DD0B 4B99 \
F62B E9A9 9167 8AAF 86D6 CE00 3460 117C 73B8 6B05 1511 E4EE \
E2B5 8603 AEC9 C84C 502E 4296 A9EF 0128 FE44 FC9C" SIGN2="1BC7 \
1B87 B802 343A 2F6D 9CDE 31B4 672C D0B5 FD80 D3C4 AD44 637E \
8295 F141 125B A74B 2064 362D AA5F F1FF C7F7 4B67 1110 6A9A \
9A8B 98F8 60BF A918 FD54"
INCREMENT PLIST adskflex 1.000 permanent 1 \
VENDOR_STRING=A07:51600ACDLAND_2007_0F:52200CIV3D_2007_0F;B07:51900AMECH_PP_2007_0F:51300INVBUN_11_0F:52900INVPRORS_11_0F:53000INVPROSIM_11_0F:51400INVPRO_11_0F;C07:51200ACD_2007_0F:52500REVITS_9_0F:54100REVITS_9_1F:53700REVSU_3_0F:54200REVSU_4_0F;D07:52600REVIT_9_0F:52500REVITS_9_0F;E07:57600ACD_2009_0P:59300INVBUN_2009_0P;F07:51800BLDSYS_2007_0F:53100REVSYP_1_0F:54500REVSYP_2_0F;G07:53400REVITST_3_0F:53700REVSU_3_0F;H07:54300REVIT_9_1F:54100REVITS_9_1F;I07:54400REVITST_4_0F:54200REVSU_4_0F;A08:55500ACDLAND_2008_0F:55400CIV3D_2008_0F;B08:54900AMECH_PP_2008_0F:55000INVBUN_2008_0F:55100INVPRORS_2008_0F:55200INVPROSIM_2008_0F:55300INVPRO_2008_0F;C08:54600ACD_2008_0F:54700REVITS_2008_0F:54800REVSU_2008_0F;D08:57100REVIT_2008_0F:54700REVITS_2008_0F;F08:55600BLDSYS_2008_0F:55700REVSYP_2008_0F;G08:57200REVITST_2008_0F:54800REVSU_2008_0F;A09:59800ACDLAND_2009_0F:59700CIV3D_2009_0F;B09:59200AMECH_PP_2009_0F:59300INVBUN_2009_0F:59400INVPRORS_2009_0F:61700INVMFG_2009_0F:59500INVPROSIM_2009_0F:59600INVPRO_2009_0F;C09:57600ACD_2009_0F:59200AMECH_PP_2009_0F:78400ACDDS_2009_0F:60900REVITS_2009_0F:61000REVSU_2009_0F;D09:62100REVIT_2009_0F:60900REVITS_2009_0F:78200RAV-S_2009_0F;F09:59900BLDSYS_2009_0F:60000REVSYP_2009_0F;G09:62200REVITST_2009_0F:61000REVSU_2009_0F;J09:67800RVTMPJ_2009_0F:60000REVSYP_2009_0F;K09:68800CIVIL_2009_0F:59700CIV3D_2009_0F;L09:60100ARCHDESK_2009_0F:60900REVITS_2009_0F:78200RAV-S_2009_0F;M09:68900NAVREV_2009_1F:78200RAV-S_2009_0F \
SUPERSEDE ISSUED=27-Jun-2011 SIGN="1B39 F158 F53E 24A1 FC8A \
1355 DCEA 5DC0 1D91 AB5F 2A2A 06D3 C97A 861C C763 1353 F215 \
37BB 5D03 E1D9 9B99 D5D7 13A6 0681 9313 C049 3E76 6B57 A603 \
D99B" SIGN2="19F0 8170 3B4A 3382 180A B599 3695 3906 DA0B FF84 \
B97F F137 09FB E00D 0783 0E20 A387 8326 B39E 1E47 1E8D 113B \
74CC 3FDB 912F 0086 2E0B AEE0 53F1 1BC7"
PACKAGE 65200REVSYP_F adskflex 1.000 COMPONENTS="85793REVSYP_2012_0F \
85624REVSYP_2011_0F 73100REVSYP_2010_0F 60000REVSYP_2009_0F" \
OPTIONS=SUITE SUPERSEDE ISSUED=27-Jun-2011 SIGN="0E06 3095 \
3EC7 C37E A341 616A 2BEC D6A7 14B2 31DD E77C E912 AAFD 0646 \
D9A1 0641 9543 2587 61BE FC45 BDF8 1917 B404 77E8 7695 7A40 \
B26C B4FE C3BE D778" SIGN2="13E0 EEE0 B4FB D1EC 7954 FD08 EC24 \
44E5 0610 D0FA E78E 82CF 7336 F10F 5D99 0012 952A D5E1 2089 \
BC7E 0F9C 89CE DF3C F241 73AF 3D03 E9E6 7699 EB54 0A58"
INCREMENT 65200REVSYP_F adskflex 1.000 permanent 16 \
SN=xxx-xxxxxxxx SIGN="090F 26C8 7B78 214F 297A B469 ED26 5F13 \
5A7E 45E3 7EFC 76FA AAA3 BA5A B1FF 1FCF 80B8 DAFC 9DAD DA83 \
AEB9 EA27 4793 642E 2769 68EE 72CA 280E 50BB 38D6" SIGN2="0582 \
4870 760D 4579 A2F0 8E3D 958F CF70 D0D6 C2BC CEF3 113B 250B \
CB0D 78AB 0083 0B2E 1755 9405 2058 B89E F7C1 5EFC EA4B AD27 \
8582 62AA 0F04 3436 A38D"
Cascading can be kind of wonky at times. Your setup should work because it seems that you've done everything right. Here's what I suggest, however, to possibly get this working.
1. Cascading had some weird issues with 2012. So you might consider upgrading to your 2013 Subscription .LIC file. This will allow you to run 2013, 2012, 2011, and 2010. Just make sure both serials are generated on the same date or the cascade will not work.
2. Upgrade your License Manager files to the latest version: http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Network-License-Manager-2013/m-p/33873...
3. Place the Revit MEP above the AutoCAD MEP in the new combined license order of the new file. Order sometimes helps the cascade issues for some reason.
4. Delete the CascadeInfo.cas file on the clients with the problem. This file facilitates cascading. It will be recreated upon the next successful launch. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=12305695
The reason I recommend the new 2013 LIC file has a couple of good reasons. One, the cascading seems to work better for 2013 licenses than the 2012 licenses did. The other reason is that your new LIC file will not have the old PLIST Increment that was used to cascade older licenses. Sometimes this causes additional issues for cascading.
Post any additional issues here.
