Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
xfgfth
559 Views, 5 Replies
Cant install..
Error attached........ where can i get Autodesk_3ds_Max_2011_English_Win_32-64bit.part2.rar?
5 REPLIES 5
ukdxb012
in reply to: xfgfth
You will need to go back to either the DVD or Autodesk Subscription.
If you obtained the media via Autodesk Subscription, you need to select 3DS Max 2011, choose Browser Download and the file for 32 and 64 Bit should be entitled "Autodesk_3ds_Max_2011_English_Win_32-64bit.part2.rar"
What file are you using thats extracting on your screenshot?
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
xfgfth
in reply to: xfgfth
As seen in this new screenshot, that is the version of 3ds i am trying to download
ukdxb012
in reply to: xfgfth
When you select Browser Download, does it ask you to save 2 files through IE to your desktop? If it doesnt then it should as this is how the media is delivered through Autodesk Subscription.
One file should be a rar (1GB) and the other should be an exe (3GB).
P.S - Any particular reason why you need 2011 and not 2014?
Duncan
Duncan Brannan
Twitter | LinkedIn
xfgfth
in reply to: ukdxb012
uhh, no it only downloads one file šŸ˜• And i need it because I have a gameassassin import plugin that only works on 2011
jeffrey.sin
in reply to: xfgfth
Hi xfgfth,
Can you try to re-download the installer from our Virtual Agent? Here's the link to the instructions on How to re-download your software using the Virtual Agent. You'll find the part 2 from there as well.
Jeffrey Sin
Autodesk Customer Support
Administrator Productivity
