Installation & Licensing
pw8154
558 Views, 3 Replies
Cant install acad 2013
I have downloaded acad 2013, but when I start setup, it immediately closes but leaves the initialisation window hanging.
I have Vista, and currently running acad 2010. Can anyone help please?
3 REPLIES 3
TravisNave
in reply to: pw8154
Please note that AutoCAD 2013 is not supported on Windows Vista.  You might be able to get it working, however you would have to provide additional information on your failure.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
pw8154
in reply to: TravisNave
Ok thanks for confirming. Before I get too bogged down with 2013, maybe I should just try 2012, or are there Vista problems with that one too? Thanks.
nrz13
in reply to: pw8154
I installed AutoCAD 2013 on Windows Vista Ultimate (32-bit version) without any issues.  Generally speaking, if the software runs on Windows 7, it should also run on Vista.  Autodesk just isn't supporting it on Vista because Microsoft was originally planning to drop support for Vista already.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Administrator Productivity
