• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Cant install acad 2013
    392 Views, 3 Replies
    04-06-2012 08:51 AM
    I have downloaded acad 2013, but when I start setup, it immediately closes but leaves the initialisation window hanging.
    I have Vista, and currently running acad 2010. Can anyone help please?
    Please use plain text.
    TravisNave
    Re: Cant install acad 2013
    04-06-2012 09:37 AM in reply to: pw8154
    Please note that AutoCAD 2013 is not supported on Windows Vista.  You might be able to get it working, however you would have to provide additional information on your failure.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    04-06-2012 12:02 PM in reply to: TravisNave
    Ok thanks for confirming. Before I get too bogged down with 2013, maybe I should just try 2012, or are there Vista problems with that one too? Thanks.
    Valued Mentor
    04-06-2012 01:17 PM in reply to: pw8154
    I installed AutoCAD 2013 on Windows Vista Ultimate (32-bit version) without any issues.  Generally speaking, if the software runs on Windows 7, it should also run on Vista.  Autodesk just isn't supporting it on Vista because Microsoft was originally planning to drop support for Vista already.
    ____________________________________________________________________________________________
    System specifications: AutoCAD 2014 64-bit, Windows 7 64-bit SP1, Intel Core i7-2600K, AMD FirePro V4900
    16GB RAM, Crucial M4 SSD, 3 Dell Monitors (2 30" 2560x1600 & 1 20" 1200x1600)
