So the problem is when im prompted to say where i wish to install the program. The installer just says that there is not enough space anywhere. I have 3 partitions and one of them has 230 GB.
So....?
Does your other partitions have less than the required space?
That's probably why. Especially if is your C:\. You need to have temp space free for installation as well as some of the profile files and other licensing functions, prerequisite installs, etc. that will have to go on C:\. From an IT standpoint, you should always have no less than 20% free space on your C:\. You might consider cleaning up some stuff and moving your virtual memory swap to your large drive.
