Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Cannot reinstall Revit 2013
- Highlight
- Email to a Friend
- Report Inappropriate Content
Had a problem with locating families in Revit 2013. Uninstalled Revit 2013. However reinstalling from usb fails.
Re: Cannot reinstall Revit 2013
- Highlight
- Email to a Friend
Copy USB to hard drive. Install from there as administrator. Make sure anti-virus and UAC is off.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Cannot reinstall Revit 2013
- Highlight
- Email to a Friend
Thank you for advise. I followed your suggestions, however still unable to reinstall. I then did a windows 7 restore system to prior to unstall, did a repair and then a reinstall from control panel. I now receive message regarding license and Revit 2013 loads in viewer mode. Any futher suggestions would be appreciated.
- Highlight
- Email to a Friend
I have spent much of the day trying to resolve this issue. Maybe I should completely uninstall Building Design Suite and reinstall, or maybe just reformat hard disk and re-install as I only use this computer for CAD and nothing else
- Highlight
- Email to a Friend
You probably will have to blow away your licensing and reactivate the product. Granted, if you're gonna reinstall Windows, then that wil also likely fix it.
- Highlight
- Email to a Friend
After using unstall utility and then uninstalling the remainder of 2013 programs from control panel and then manually blowing away anything relating to Autodesk 2013, I have finally reinstalled building design suite on the second attempt. I still have my original problem with no family template. Revit.ini refers to chinese folder, which does not exist. I did a repair and the Australia content was ticked but not installed. I have included Autodesk.com in internet trusted sites, but still no families.
- Highlight
- Email to a Friend
Check out my last post here, in regards to your libraries and templates not installing.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
- Highlight
- Email to a Friend
Finally got Revit 2013 as it should be.. Australia Content and templates loaded correctly.
I think the issue was partly due to Building Design Suite and the folders created.
After help from this forum and Autodesk I have all systems are go....
Thank You
