• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Cannot reinstall Revit 2013
    1401 Views, 7 Replies
    04-24-2012 12:08 PM
    Had a problem with locating families in Revit 2013. Uninstalled Revit 2013. However reinstalling from usb fails.
    Please use plain text.
    TravisNave
    Re: Cannot reinstall Revit 2013
    04-24-2012 01:16 PM in reply to: steve
    Copy USB to hard drive.  Install from there as administrator.  Make sure anti-virus and UAC is off.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    04-24-2012 04:48 PM in reply to: TravisNave
    Thank you for advise. I followed your suggestions, however still unable to reinstall. I then did a windows 7 restore system to prior to unstall, did a repair and then a reinstall from control panel. I now receive message regarding license and Revit 2013 loads in viewer mode. Any futher suggestions would be appreciated.
    04-24-2012 09:39 PM in reply to: steve
    I have spent much of the day trying to resolve this issue. Maybe I should completely uninstall Building Design Suite and reinstall, or maybe just reformat hard disk and re-install as I only use this computer for CAD and nothing else
    TravisNave
    04-25-2012 07:10 AM in reply to: steve
    You probably will have to blow away your licensing and reactivate the product.  Granted, if you're gonna reinstall Windows, then that wil also likely fix it.
    Travis Nave
    04-26-2012 09:38 AM in reply to: TravisNave
    After using unstall utility and then uninstalling the remainder of 2013 programs from control panel and then manually blowing away anything relating to Autodesk 2013, I have finally reinstalled building design suite on the second attempt. I still have my original problem with no family template. Revit.ini refers to chinese folder, which does not exist. I did a repair and the Australia content was ticked but not installed. I have included Autodesk.com in internet trusted sites, but still no families.
    Employee
    04-26-2012 10:53 AM in reply to: steve
    Check out my last post here, in regards to your libraries and templates not installing.
    http://forums.autodesk.com/t5/Installation-Licensing/Revit-2013-Failed-Installation-aborted-Result-1...
    Danny
    Danny Hubbard
    QA Analyst
    04-28-2012 08:57 PM in reply to: DannyHubbard
    Finally got Revit 2013 as it should be.. Australia Content and templates loaded correctly.
    I think the issue was partly due to Building Design Suite and the folders created.
    After help from this forum and Autodesk I have all systems are go....
    Thank You
