Installation & Licensing
steve
Message 1 of 8 (1,608 Views)
Cannot reinstall Revit 2013
1608 Views, 7 Replies
04-24-2012 12:08 PM
Had a problem with locating families in Revit 2013. Uninstalled Revit 2013. However reinstalling from usb fails.
TravisNave
Message 2 of 8 (1,606 Views)
Re: Cannot reinstall Revit 2013
04-24-2012 01:16 PM in reply to: steve
Copy USB to hard drive.  Install from there as administrator.  Make sure anti-virus and UAC is off.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
steve
Message 3 of 8 (1,597 Views)
04-24-2012 04:48 PM in reply to: TravisNave
Thank you for advise. I followed your suggestions, however still unable to reinstall. I then did a windows 7 restore system to prior to unstall, did a repair and then a reinstall from control panel. I now receive message regarding license and Revit 2013 loads in viewer mode. Any futher suggestions would be appreciated.
steve
Message 4 of 8 (1,590 Views)
04-24-2012 09:39 PM in reply to: steve
I have spent much of the day trying to resolve this issue. Maybe I should completely uninstall Building Design Suite and reinstall, or maybe just reformat hard disk and re-install as I only use this computer for CAD and nothing else
TravisNave
Message 5 of 8 (1,585 Views)
04-25-2012 07:10 AM in reply to: steve
You probably will have to blow away your licensing and reactivate the product.  Granted, if you're gonna reinstall Windows, then that wil also likely fix it.
steve
Message 6 of 8 (1,568 Views)
04-26-2012 09:38 AM in reply to: TravisNave
After using unstall utility and then uninstalling the remainder of 2013 programs from control panel and then manually blowing away anything relating to Autodesk 2013, I have finally reinstalled building design suite on the second attempt. I still have my original problem with no family template. Revit.ini refers to chinese folder, which does not exist. I did a repair and the Australia content was ticked but not installed. I have included Autodesk.com in internet trusted sites, but still no families.
Employee
DannyHubbard
Message 7 of 8 (1,562 Views)
04-26-2012 10:53 AM in reply to: steve
Check out my last post here, in regards to your libraries and templates not installing.
http://forums.autodesk.com/t5/Installation-Licensing/Revit-2013-Failed-Installation-aborted-Result-1...
Danny
Danny Hubbard
QA Analyst
steve
Message 8 of 8 (1,543 Views)
04-28-2012 08:57 PM in reply to: DannyHubbard
Finally got Revit 2013 as it should be.. Australia Content and templates loaded correctly.
I think the issue was partly due to Building Design Suite and the folders created.
After help from this forum and Autodesk I have all systems are go....
Thank You
