Installation & Licensing
Cannot install - buttons are not available of license screen?
1 REPLY 1
226 Views, 1 Reply
I have made several attempts to download AutoCAD 13 to my computer and every time I get to the license agreement screen, the prompt buttons to go to the next screen (next, back, cancel) are below the visibile area of my screen.  I cannot manipulate the window in any way.  I cannot change the size of the window, minimize it, or move it so that I can click next to finish the install.
I do not know what to do and really need to be able to use CAD this week.
Would appreciate any advice.
Crystal
1 REPLY 1
TravisNave
Your screen resolution does not meet the minimum requirements to run the program.  If you cannot increase your screen res to at least 1024x768 then you can try attaching an external monitor.  However, my guess is that if your screen does not meet minimum requirements, the rest of your hardware might also be lacking and you will not have a desireable software experience.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
