Hey guyz plz help me out. i am not able to instal maya 2014 even after i clean the registry. Setup still shows maya already installed .. 😞
Also, this link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16508079&linkID=9240617 (Which is on the MSI cleanup page in the second post) takes me here: http://knowledge.autodesk.com/support/autocad.
Ok, I found where the link was. For some reason it wasn't showing up when I searched that page before. I have went through the steps and have tried to install the newest version of Maya. I got this error message:
Source file not found: 93437458-FD45-41D9-8F2E-8B4F60CF9356.DLL verify that the file exists and that you can access it.
I know that this file does exist because I'm looking right at it.
I don't actually have a disk for it, I'm using the student download for the installer. Now that my semester is over I haven't had as hard a time responding in a timely fashion.
Hey guys i'm trying to install MAYA 2013 and i had it before, on my new laptop it is giving me installation issues. I tried most of the things on the forum except overriding the install with code because i dont know how to do that. Well, in the log I believe the issue is with my DirectX and it says failure, everytime i attempt. Any help, please? Email me at telfortsam@yahoo.com or reply. I need my MAYA
2014/7/17:19:21:43 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:19:21:43 Samnold SAMNOLD Launch
2014/7/17:19:21:43 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/17:19:21:54 Samnold SAMNOLD === Setup ended ===
2014/7/17:19:21:48 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:19:21:48 Samnold SAMNOLD Launch
2014/7/17:19:21:50 Samnold SAMNOLD Download Skipped SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/SETUP_x64.tar...
2014/7/17:19:21:54 Samnold SAMNOLD PageOpen LaunchDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen LicenseDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen ProductInfoDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen ProductSelectionDialog2
2014/7/17:19:28:29 Samnold SAMNOLD PageOpen FullProgressDialog
2014/7/17:19:28:31 Samnold SAMNOLD Download Skipped DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/DIRECTX.tar.l...
2014/7/17:19:28:31 Samnold SAMNOLD Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Maya 2013\3rdParty\DirectX\DXSETUP.exe /silent
2014/7/17:19:31:11 Samnold SAMNOLD Install DirectX® Runtime Succeeded
2014/7/17:19:31:15 Samnold SAMNOLD Download Play Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:20:10:45 Samnold SAMNOLD Download Aborted Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:20:10:45 Samnold SAMNOLD Install Autodesk® Maya® 2013 Failed Download Failed, Installation aborted, Result=1603
2014/7/17:20:10:48 Samnold SAMNOLD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/7/17:20:10:49 Samnold SAMNOLD PageOpen InstallCompleteDialog
2014/7/17:20:16:59 Samnold SAMNOLD === Setup ended ===
2014/7/17:20:21:04 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:20:21:04 Samnold SAMNOLD Launch
2014/7/17:20:21:04 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/17:20:21:13 Samnold SAMNOLD === Setup ended ===
2014/7/17:20:21:10 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:20:21:10 Samnold SAMNOLD Launch
2014/7/17:20:21:11 Samnold SAMNOLD Download Skipped SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/SETUP_x64.tar...
2014/7/17:20:21:13 Samnold SAMNOLD PageOpen LaunchDialog
2014/7/17:20:41:13 Samnold SAMNOLD PageOpen LicenseDialog
2014/7/17:20:41:14 Samnold SAMNOLD PageOpen ProductInfoDialog
2014/7/17:20:41:15 Samnold SAMNOLD PageOpen ProductSelectionDialog2
2014/7/17:20:43:44 Samnold SAMNOLD PageOpen FullProgressDialog
2014/7/17:20:43:45 Samnold SAMNOLD Download Skipped DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/DIRECTX.tar.l...
2014/7/17:20:43:45 Samnold SAMNOLD Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Maya 2013\3rdParty\DirectX\DXSETUP.exe /silent
2014/7/17:20:50:56 Samnold SAMNOLD Install DirectX® Runtime Succeeded
2014/7/17:20:50:58 Samnold SAMNOLD Download Play Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:21:12:05 Samnold SAMNOLD Download Aborted Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:21:12:05 Samnold SAMNOLD Install Autodesk® Maya® 2013 Failed Download Failed, Installation aborted, Result=1603
2014/7/17:21:12:08 Samnold SAMNOLD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/7/17:21:12:10 Samnold SAMNOLD PageOpen InstallCompleteDialog
2014/7/17:21:16:36 Samnold SAMNOLD === Setup ended ===
2014/7/17:23:13:36 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:23:13:36 Samnold SAMNOLD Launch
2014/7/17:23:13:36 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
Hi @telfortsam,
Apologies for the late reply! Would you mind trying this Autodesk Solution on how to resolve the 1603 error? Thanks!
