Alright. Fair warning: It's pretty long. 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC CommandLine /url "
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-20484795 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:29:22 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AIA65D.tmp 2014/3/26:09:29:26 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:29:23 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:29:23 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:29:23 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AIA65D.tmp 2014/3/26:09:29:23 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:29:23 Searnadrix SEARNADRIX-PC Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x... 2014/3/26:09:29:26 Searnadrix SEARNADRIX-PC PageOpen LaunchDialog 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC CommandLine /url "
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-20484795 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:30:56 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI197A.tmp 2014/3/26:09:31:02 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:30:58 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:30:58 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:30:58 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI197A.tmp 2014/3/26:09:30:58 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:30:59 Searnadrix SEARNADRIX-PC Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x... 2014/3/26:09:31:00 Searnadrix SEARNADRIX-PC PageOpen LaunchDialog 2014/3/26:09:31:06 Searnadrix SEARNADRIX-PC PageOpen LicenseDialog 2014/3/26:09:31:06 Searnadrix SEARNADRIX-PC PageOpen ProductInfoDialog 2014/3/26:09:31:06 Searnadrix SEARNADRIX-PC PageOpen ProductSelectionDialog2 2014/3/26:09:31:26 Searnadrix SEARNADRIX-PC PageOpen FullProgressDialog 2014/3/26:09:31:26 Searnadrix SEARNADRIX-PC Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX... 2014/3/26:09:31:26 Searnadrix SEARNADRIX-PC Installing DirectXÂŽ Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/26:09:31:26 Searnadrix SEARNADRIX-PC Install DirectXÂŽ Runtime Failed Failure is ignored, Result=-9 2014/3/26:09:31:27 Searnadrix SEARNADRIX-PC Download Skipped Maya
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en... 2014/3/26:09:31:29 Searnadrix SEARNADRIX-PC Installing AutodeskÂŽ MayaÂŽ 2014: TRANSFORMS="C:\Users\SEARNA~1\AppData\Local\Temp\_AI197A.tmp\x64\Maya\Maya2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2014" INSTALLDIR="C:\Justins Programs\Autodesk\Maya\Maya2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/26:09:37:04 Searnadrix SEARNADRIX-PC Install AutodeskÂŽ MayaÂŽ 2014 Failed Installation aborted, Result=1603 2014/3/26:09:37:04 Searnadrix SEARNADRIX-PC PageOpen InstallCompleteDialog 2014/3/26:09:37:06 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC Current Directory C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC CommandLine 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:54:22 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI8C87.tmp 2014/3/26:09:54:31 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:54:27 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:54:27 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:54:27 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI8C87.tmp 2014/3/26:09:54:27 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:54:31 Searnadrix SEARNADRIX-PC PageOpen LaunchDialog 2014/3/26:09:54:35 Searnadrix SEARNADRIX-PC PageOpen LicenseDialog 2014/3/26:09:54:39 Searnadrix SEARNADRIX-PC PageOpen ProductInfoDialog 2014/3/26:09:55:25 Searnadrix SEARNADRIX-PC PageOpen ProductSelectionDialog2 2014/3/26:09:55:54 Searnadrix SEARNADRIX-PC PageOpen FullProgressDialog 2014/3/26:09:55:54 Searnadrix SEARNADRIX-PC Installing DirectXÂŽ Runtime: "C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/26:09:57:06 Searnadrix SEARNADRIX-PC Install DirectXÂŽ Runtime Succeeded 2014/3/26:09:57:08 Searnadrix SEARNADRIX-PC Installing AutodeskÂŽ MayaÂŽ 2014: TRANSFORMS="C:\Users\SEARNA~1\AppData\Local\Temp\_AI8C87.tmp\x64\Maya\Maya2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm\" INSTALLDIR="C:\Justins Programs\Autodesk\Maya\Maya2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/26:09:58:46 Searnadrix SEARNADRIX-PC Install AutodeskÂŽ MayaÂŽ 2014 Failed Installation aborted, Result=1603 2014/3/26:09:58:46 Searnadrix SEARNADRIX-PC Rollback DirectXÂŽ Runtime Failed Failure is ignored, Result=1619 2014/3/26:09:58:46 Searnadrix SEARNADRIX-PC PageOpen InstallCompleteDialog 2014/3/26:09:59:05 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC Current Directory C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC CommandLine 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:59:19 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI14BA.tmp 2014/3/26:09:59:23 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:09:59:21 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:09:59:21 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:09:59:21 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI14BA.tmp 2014/3/26:09:59:21 Searnadrix SEARNADRIX-PC Launch 2014/3/26:09:59:23 Searnadrix SEARNADRIX-PC PageOpen LaunchDialog 2014/3/26:09:59:37 Searnadrix SEARNADRIX-PC PageOpen LicenseDialog 2014/3/26:09:59:39 Searnadrix SEARNADRIX-PC PageOpen ProductInfoDialog 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC Current Directory C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC Launch 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC CommandLine 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:10:00:59 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI9D2A.tmp 2014/3/26:10:01:12 Searnadrix SEARNADRIX-PC === Setup ended === 2014/3/26:10:01:04 Searnadrix SEARNADRIX-PC === Setup started on SEARNADRIX-PC by Searnadrix === 2014/3/26:10:01:04 Searnadrix SEARNADRIX-PC Path_Length: 151 2014/3/26:10:01:04 Searnadrix SEARNADRIX-PC Current Directory C:\Users\SEARNA~1\AppData\Local\Temp\_AI9D2A.tmp 2014/3/26:10:01:04 Searnadrix SEARNADRIX-PC Launch 2014/3/26:10:01:08 Searnadrix SEARNADRIX-PC PageOpen LaunchDialog 2014/3/26:10:01:14 Searnadrix SEARNADRIX-PC PageOpen LicenseDialog 2014/3/26:10:01:16 Searnadrix SEARNADRIX-PC PageOpen ProductInfoDialog 2014/3/26:10:01:24 Searnadrix SEARNADRIX-PC PageOpen ProductSelectionDialog2 2014/3/26:10:01:45 Searnadrix SEARNADRIX-PC PageOpen FullProgressDialog 2014/3/26:10:01:45 Searnadrix SEARNADRIX-PC Installing DirectXÂŽ Runtime: "C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/26:10:03:02 Searnadrix SEARNADRIX-PC Install DirectXÂŽ Runtime Succeeded 2014/3/26:10:03:04 Searnadrix SEARNADRIX-PC Installing AutodeskÂŽ MayaÂŽ 2014: TRANSFORMS="C:\Users\SEARNA~1\AppData\Local\Temp\_AI9D2A.tmp\x64\Maya\Maya2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Justins Programs\Autodesk\Autodesk_Maya_2014_dlm\" INSTALLDIR="C:\Justins Programs\Autodesk\Maya\Maya2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/26:10:04:10 Searnadrix SEARNADRIX-PC Install AutodeskÂŽ MayaÂŽ 2014 Failed Installation aborted, Result=1603 2014/3/26:10:04:10 Searnadrix SEARNADRIX-PC Rollback DirectXÂŽ Runtime Failed Failure is ignored, Result=1619 2014/3/26:10:04:10 Searnadrix SEARNADRIX-PC PageOpen InstallCompleteDialog 2014/3/26:10:35:35 Searnadrix SEARNADRIX-PC === Setup ended ===
